Sealing a new motor
I have a new Novarossi NS12 5 port. Someone at the local track suggested that I seal the front case, carb and high speed needle housing as a standard practice. What are you guy's take on this and what are you using. I did a search a saw where one guy mentioned Permatex Ultra Blue. What instructions and suggestions do you guys have for doing this.
This can be a good practise, but very very careful to use the sealant sparingly.
Sealing a motor
There is not need to seal it if it is still new as the S5 is well built. What you might need to seal is the area where the rubber boot meets the carb, a little sealant there will stop any leaks. Also a little cable tie would do well there.
My S5 has been stripped about 3 times now and its still doing well. No leaks ... |
Re: Sealing a new motor
Originally posted by jcrouse I have a new Novarossi NS12 5 port. Someone at the local track suggested that I seal the front case, carb and high speed needle housing as a standard practice. What are you guy's take on this and what are you using. I did a search a saw where one guy mentioned Permatex Ultra Blue. What instructions and suggestions do you guys have for doing this. |
I put a zip tie around the boot and secure it to the carb and superglue the other end of the boot.
Originally posted by EVOLUTION I put a zip tie around the boot and secure it to the carb and superglue the other end of the boot. |
Originally posted by Top Gun 777 This will work perfectly-I will do the same with CA glue. |
Looking for more opinions!
Re: Looking for more opinions!
Originally posted by jcrouse Bump |
Plastic tie around the boot to secure it to the carb and superglue on the other end to secure it to the slide and make sure no air gets sucked in. :D
I saw someone put a rubber band on a carb !! who is that idiot? :lol: :lol: :lol: :lol:
Originally posted by Manticore I saw someone put a rubber band on a carb !! who is that idiot? :lol: :lol: :lol: :lol: |
Rubber band
Don't laugh so fast, where was the rubber band? I use a rubber band to hold the slide carb back in case there is a sudden loss of RX power! This is something no fail safe can help you in the event that you somehow loose RX power!
i agree rubber band is also a failsafe.... been there done that.
works like a charm. |
