Engine Wars Thread
#46
Re: Re: Re: Re: Where is everybody?
Originally posted by Data
thanks for the reply, now i have more questions.
how would the shape and angle of the squish band affect the performance? As you said, the design of the squish band changes from engine to engine, but what is the general guide line the designer would follow ?
#47
Originally posted by fastharry
well,theres got to be some benefit(you would think).....but I'm curious as to the reason..shape,extra coil in the filament,takes up more cyl space for more compression....
I know they don't recommend them for off road use,as they are more fragile.....and harder to tune..
Hmmm..
Hmmm..
#48
This plug will give real benefit.
#49
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Nice to have an RC conversation..
hope its not ruined 2 hours from now..
#50
#51
no..its me they'll be after...
Watch..
Watch..
#52
Watch..
Watch..
#53
Originally posted by Top Gun 777
What are you talking about? Who are they? Who cares if they exist? Who is going to stop me here or somewhere else? Are you kidding me? People come here to say something or ask question, or or share expirience, if somebody doesn't like it-it there problem and it means they are hiding something from people-I don't care if I open some secrets or so. I will say whatever I want to, about anyhting I want to.
#54
I have used both standard plugs and turbo plugs and I actually do think that there is a very slight performance difference with the turbo plug. BUT I think that it only becomes obvious when the engine becomes older.
On a standard head repeated plug removal and replacement wears the thread of the head down and it becomes a potential source for compression leakage. Similarly that stupid brass washer on the plug gets crushed and flattened out and alters the glow plug position slightly.
Turbo plugs seal the head chamber up really tight and always key into the right position. Also the actual face that goes into the chamber is much smaller meaning the shape of the chamber is less affected by the shape of the glowplug.
I have no scientific evidence to back this all up of course.
#55
and how does the shape of a TURBO plug help performance.....
#56
#57
i'm not sure about this but the dome shape
in the button is designed to bring fuel and
air mixture as close to the center of the
glow plug if you go with a flat shaped button
the engine might not be as efficient due to
the nitro mixture will not be directed towards
the glow plug as for different designs ive
noticed that some modifiers make a cut
on the button on the side where to boost
port is or on the exhaust side on the button
but they do not try to change the cumbustion
shape just the edges to help flow i guess.
i would be carfull not too leave sharp edges
when doing this modification as it will retain
heat and could cause preignition sometime
when the engine gets up to temp.
#58
This is looks like real difference between turbo and regular plug. But if you pay attencion to the turbo thred-you will know it is much finner. I think it is easier to damge it if some debry will get there-specialy aluminum-it will ruined in second, but I am not sure, it just seems for me like this. What I saw in a lot of engines-which is realy shoked me-a lot of people use head shims made out of cooper-I would never do it, only soft AL.
My plug threads are still OK at the moment, seems to be undamaged so far.
#59
Dear TOP GUN,
We all know that higher exhaust port can move the torque/rpm curve to the high-rpm zone.But we will lost some torque on the bottom and get instable idle.What do you think between high-rpm engine and high-torque engine?Whatever we can change the gear ratio for them to fit for the track.Which one is your favorite?
Thanks in advance.
Thanks in advance.
#60
There is a photo to explain the TURBO PLUG.It can fix the content of the combustion chamber no matter which brand's turbo plug using on your engine.The purpose is the same with TOP GUN's antique Rossi.
