Old 08-12-2003, 04:34 AM   #1
spitfire's Avatar
Send a message via AIM to spitfire Send a message via Yahoo to spitfire
Default Sirio carb options?
IS there another carb out there that fits? i think mines leaking bad but i heard not to use the composite carb?
spitfire is offline   Reply With Quote
Old 08-12-2003, 05:36 AM   #2
Trader Rating: 49 (100%+)
I am currently using a Novarossi carb and it works fine. So I know they will fit.
rodneybarrett is offline   Reply With Quote
Old 08-13-2003, 07:24 PM   #3
mckrooz's Avatar
Send a message via AIM to mckrooz
Yup, guys are using the Novarossi carbs. The MT12 or MR12 carb fits.
mckrooz is offline   Reply With Quote
Old 08-14-2003, 04:39 AM   #4
kt racing's Avatar
Send a message via AIM to kt racing
I'm using the carbon carb and I haven't had a problem with it.
kt racing is offline   Reply With Quote
Old 08-14-2003, 12:24 PM   #5
So far I havent had a problem with my stock 3 needle composite carb, its very responsive to tuning and I can run the engine with awsome performance between 200 and 210F. I think I might have a leaky front bearing though After I fill the engine up with after run oil and come back the next day theres a small puddle of ARO under the car. This could be because I nearly flood the engine with ARO though, I rusted a crank once so Im not taking any chances with this engine.
AE Racer is offline   Reply With Quote
Old 08-16-2003, 08:11 AM   #6
Send a message via ICQ to edgar
Default carb problems
What type of leaks are you guys experiencing?
I distribute Sirio in my country and from what I know, the earlier batches of .12 engines had a loose low-end carb slide-side needle. This caused the needle to turn too easily and caused some air leaks. Remedy for this problem was to put a little (and I stress only a little ) loctite 242 on the thread of this needle and put it back in. You will have then a bit tight turning needle but now without leaks.
Another problem we encountered was with the carb retaining pin. The pin diameter are just too small and caused air leaks too. After running you will notice oil/dirt collecting at the pin's ends. To cure this, just coat the pin and hole with very little amount of silicone gasket maker and wipe off the excess before installing back the carb on the crankcase. This way you will be able to have a good and stable idling engine.
Good news is that Sirio has corrected the low-end needle problem and have also added a second o-ring inside the crankcase below the retaining pin level.
Hope this helps you guys out! Enjoy!
edgar is offline   Reply With Quote
Old 08-16-2003, 08:36 AM   #7
my sirio .12 is the best motor I've ever owned, its tunes nicely, runs at 220 all day in the heat and will idle the whole tank without dying, what more do you want?
Josh K. is offline   Reply With Quote
Sirio evo III with STI Options installed + enough spares for another engine TomB Australia For Sale/Trade 6 05-01-2007 03:35 AM
Carb sirio 27 Help PLease gumby112087 Monster Trucks 3 11-19-2004 03:09 PM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Onroad Nitro Engine Zone 10 09-25-2004 08:29 AM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Nitro On-Road 5 12-15-2003 02:24 PM
Sirio carb? Vue Vang Nitro On-Road 6 06-03-2003 09:10 AM
SEO by vBSEO 3.5.0
