New w/questions >
New w/questions
New w/questions
Old 06-15-2008, 05:10 PM
Default New w/questions
I am new at this I was wondering what is a good nitro car for a newbe to start out with I can get use to and then hop up any help would be greatly appreciated
rcwarrior1 is offline
Old 06-15-2008, 05:31 PM
Trader Rating: 26 (100%+)
get a tc3 rtr kit it's a good car to start with
RANDY SMOOTH is offline
Old 06-15-2008, 08:58 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
I see you are in MD. Do you plan on running at 301? If so, head out there on a weekend and talk to some of the other racers. You might even be able to find a deal on used car ready to go.
www.301raceway.com
wingracer is offline
Old 06-16-2008, 08:56 AM
I am actually planning on running at Blue Diamond park I went out there yesterday. They have a good track
Old 06-16-2008, 09:20 AM
If my car is a pull start do I still need a starter box what are they used for. Can someone please help me
Old 06-16-2008, 09:51 AM
Team Speedy's Avatar
Trader Rating: 55 (100%+)
No a pull start is a pull start. You pull it to start it. Inside there is a string and a spring with a loaded tension to kick it over. It starts just the way a weedeater or leaf blower would start.
A bump start is used to kick over the fly wheel found on the engine itself for engines without a pull start. I know for a fact that a lot of the cars you'll see at Blue Diamond Park will be bump start. Most of those cars there will be a Serpent, Mugen or Kyosho and possible an Xray or two running around.
If need be there is a thread in the racing section called Blue Diamond 2008. Check it out and we'll give you a hand. I know a good bit of those guys that run there, they are all friendly, helpful and a blast to race with. Trust me, I've been around them since 2001.
Team Speedy is offline
Old 06-16-2008, 01:19 PM
thanks for your help
Old 06-17-2008, 01:55 PM
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
pm sent
sm1nts2escape is offline
Old 06-17-2008, 05:03 PM
nObRaIn's Avatar
You should also consider kyosho's fw05 or fw06, assuming kyosho is well supported in your area. I think the tc3 is a bit outdated and requires more effort to get competitive. The fw05/06 provides a good starting point, and you can upgrade it to a proper racer as you grow. Part availability and local support should be your first priority anyway.
nObRaIn is offline
