Old 08-10-2003, 07:39 PM   #1
Default Questions About Ntc3
Ive been wanting to get a NTC3 and i finally got the kit.......i wanna know if i can put a bigger engine on it, maybe a .15 or .18, would i have to buy a conversoin kit??? Also how fast does a NTC3 go with a 2 speed tranny and how fast with a one speed??
MercadesCLK is offline   Reply With Quote
Old 08-10-2003, 08:53 PM   #2
Send a message via AIM to 2Hard2Handle
well if you want to buy a .15 or a .18 it depend on what you want a rear or a side engine and when you bought that kit was it a rear or a side type of kit? and if you put a 2 speed well like i said it depend one what engine you get try to give us more info on what kinda engine you like side or rear
2Hard2Handle is offline   Reply With Quote
Old 08-11-2003, 10:58 AM   #3
It's pretty simple. Any small block .15 or .18 will fit the motor mounts. You need an engine with either a pilot (SG) shaft or you need to cut down the threaded shaft to fit. AE sells a cut off nut that helps to do this.
Now the fun part, did you buy a pull-start kit or non? The side exaust parts are in the pull-start kit and the rear exhaust parts are on the non-pull-start kit. You can always buy the parts you need to go from one to the other.
AreCee is offline   Reply With Quote
Old 08-21-2003, 04:40 PM   #4
Default Sorry took solong to respond
i got the pull start
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-10-2008 11:03 PM
NTC3 steering rack questions. bo_barger Nitro On-Road 2 03-31-2008 10:03 AM
NTC3 questions SeanZ0r Nitro On-Road 2 07-23-2007 10:55 PM
Building my NTC3 and bought a MUGEN MT.12 motor for my NTC3..good choice? need advise JDMboy Nitro On-Road 8 08-09-2004 08:31 AM
Barrel to Slide carb for NTC3 questions SeventyGTX Nitro On-Road 2 02-08-2004 08:15 AM
SEO by vBSEO 3.5.0
