Old 06-06-2008, 01:39 PM   #1
Default help with RS4 RTR 2
my rs4 2 keep drifting right. when i trim with the radio it makes right front tire wears out very quickly. i think it is my rear left tire, it is toe in alot more then the right rear side. there is no way to toe it out. does anyone have any tips or tricks to get it toe out without the adjuster?
Vi3tPhantom is offline   Reply With Quote
Old 06-06-2008, 08:46 PM   #2
Little_Mike's Avatar
yikes that is REALLY weird for a non-adjustable toe car.
Im only familiar with the RS4 3 Evo+, but im assuming they are not too different on adjustability.
First I would check and see if any of the parts (especially the A-arm or the little mounting blocks attached to the chasssis plate that connect with the A-arm) are deformed or twisted. I Think there are some little metal braces that connect the front and back of hingepins, changing the length of these alters toe (or example shortening the front brace or lentgthening the rear brace increases toe in, and vice versa). Thats really all I can think of , i hope it helps. If it dosn't, see if you can post some pics, that would be helpful.
- The little guy
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 06-07-2008, 04:26 AM   #3
i was looking over some picture of the rs4 2 and all of them have the rear toe in. is there any other way to keep it going straight during acceleration.
SEO by vBSEO 3.5.0
