Old 05-19-2008, 06:38 AM   #1
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default heavy vs soft clutch spring ??
General question
What on track differences would you see from a standard clutch spring with heavy tension on clutch nut versus very stiff spring with light tension on clutch nut.
standard mrx4x spring versus orion crf spring.
J.Gonzalez is offline   Reply With Quote
Old 05-19-2008, 07:16 AM   #2
spenzalii's Avatar
Send a message via AIM to spenzalii
I think one benefit would be the spring being able to hold it's tension longer, this keeping the clutch pressure constant over a longer period of time. With the longer mains and the heat generated by the clutch engaging and disengaging, a spring will eventually soften and loose tension. I know most people at my track with the MTx4 jump straight to the super hard MSR spring before they even build it. Haven't tried the Orion spring yet though.
But I could be wrong....
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 05-19-2008, 07:35 AM   #3
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I had the chance to run the orion spring and it is a good spring. Hits like a ton of rocks when setup correctly. Very good for high grip conditions. I like the softer springs for when tracks are loose or low grip. Sometimes its hard to get all the power to the ground. Its hard to answer the question you asked. You have to take into account track conditions and what shoe you were running?
For qualifiying, I like to run a softer spring tightend down with a soft shoe, but in the mains, a harder spring and hard shoe.. thats just me. others, run the same all the time
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 05-25-2008, 07:44 AM   #4
bboy's Avatar
Harder spring = more explosive. Try it and you will not go back.
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
I need a clutch spring how to salteen Nitro Off-Road 3 11-10-2007 04:00 AM
werks clutch spring dotan23 Nitro Off-Road 3 08-23-2007 01:10 AM
Mbx5r clutch spring help newbie2006 Nitro Off-Road 3 07-22-2007 12:24 AM
Off-Road Nationals Tire Sale: New & Used: Panther Soft and Med Soft: Switchs Bobcats DustinR R/C Items: For Sale/Trade 9 07-11-2007 04:59 AM
[FS] Corally Black Spring Kit (soft) #79230 squarehead R/C Items: For Sale/Trade 3 11-03-2005 06:48 AM
SEO by vBSEO 3.5.0
