Kyosho FW-05R
#121
Originally posted by Sp Racer
1/ The car is horribly under geared, at England Park ,60-65 meter back straight, using a 29t second gear (and that is the bigest you can get!) it would still be wound out about 2/3 of the way (I used a Novarossi NS3);..that was with 60mm foam tyres!
#122
I have the same experience as SP racer, the car handle great but the crown gear wouldn't last too long. As for gearing, I only fine it a little under gear, the 39T crown gear should make it better.
Also whoever that is running this car should also try to grind the head of the 2.6mm screw for adjusting the 2nd speed shorter so that it will not come in contact with the 2nd gear while idling or running in 1st speed.
#123
What exhuast system are u guys running with this car and is any modification required to fit.
#124
I was coverting all my left side pipe to use on my FW05R, all you need to do is to removed the presure nipple, block the hole and refit in onto the opposite side. However I have just brought a proper right side pipe - OS T1031, this is the same as the T1030 but the have the nipple on the other side. Anyone of try one of this pipe?
#125
A bunch of racers at my track uses the 1030. Excellent all around power and very dent resistant compared to those soft pipes that are the norm. A bit pricey though but worth it.
I have one(1030) but I still didn't install it since I got it two months ago. It's too darn nice.
#126
Originally posted by FREAKAH
...I have one(1030) but I still didn't install it since I got it two months ago. It's too darn nice.
I didn't realize the pipe for right side engines had a different parts#... I should check that the next time I go in (when I work, I always ending handing the right-side pipe to the guys that need the left-side pipe ).
#128
For the one who is interested,Kyosho will release FW05S this fall.The kit will include GS15R and pipe set.
#129
For those who can't believe their eyes, I have released a shark pipe with no performance lose on the 05R. . .
ahem . . just joking. . .
#130
shim settings
Was hoping someone might be able to enlighten me on setting up backlash on the FW05R (crown and pinion). Im new to shimming and dont want set the gears wrong and destroy them.
just need a push in the right direction, what spacer settings (.1 & .2 on left or right side) have you guys got setup so i can know what to feel.
any help much appreciatted...
#132
Hey Sp Racer how the shaftie going. It looked good at the Nats.
#133
Ok hachiroku , here goes.
Don't worry about the number of shims, what you do is assemble the diff as shown in the pic, the push it from right (1) to left as far as it will go,Have a look at the gap between the bearing (1) and the housing, this will show you the total amount of shims you'll need to use.
Once you've filled that gap full of shims ( in my car I think I used 2 x 0.2 and 2 x 0.1 shims), start swapping them from right (1) to left(2) until you have the desired backlash.
If they are ever so slightly notchy, that's ok, they'll smooth out after a couple of runs.
If you can't understand this, PM me!
LS
LS
