Kyosho FW-05R
#4921
has anybody had a problem with breaking front axles? i have, i just touch the boards and snap there goes another. wood boards. two day race this weekend and broke one in 4 out of 5 qualifiers. managed to keep it off the boards for the 30 min a main. qualed 3rd and finished 5th. guy from canada was kinda scary when he got behind ya. little too choppy on the corners. makes ya nervous as hell. could have done better but broke too many times. got to challenge a rrr and the guy was fast, but i still got to make some killer passes on the rrr. just too much fun whoopin up on the belt car. shaft drive rules. i did manage to finish one position in front of the rrr. yeah the car worked great, now if i could get the driver to keepit off the boards! later all.
doug...
doug...
#4922
got a big prob with keepin the front dogbones in the car, every time i have a slight tangle it throws a bone. runnin the standard setup, even put o rings on both sides,still didn't work. any tip would be handy. cheers tigg
#4923
What width are you running at the front? Maybe you need to make the track width a bit smaller so they cant pop out? Can you move them back and forth very far when you have it assembled?
#4924
about 195mm any more an i can't adjust the toe in,
#4925
Dogbones fall out of the front in most cars, more so if you have a lot of steering lock.
You'd be best putting some universals up front.
#4926
#4927
thx i'll get sum
#4928
toe-in/out for fw-05rr?
I've been tinkering some minor settings and getting ready to mount my new titan body on my fw-05 and can't help but notice there's no way to adjust the front toe-in/out. How do we adjust these in the fw-05rr?
#4929
#4930
Originally Posted by OrAnGe PoWeR
Hi ch4dwick! Get a turnbuckle for the steering linkage. Otherwise, you can pop out one side of the linkage and twist it for length adjustments. You can also use the turnbuckles that came with your rear anti-roll bar for your steering paired with one short and one medium plastic ballends on each side. Good Luck!
#4932
Originally Posted by impalabob64
let just say holy #$#$ the fwo is like a rocket 20/51,27/45. man i had a battle with a rrr on a super smooth flat track no bumps ,as we all know the fwo performs at its best on a flat track.
#4933
is there an easy way to unhook those adjusters to ball ends? I always find myself working myself out removing those tight things. I did find one solution though. instead of yanking it, I twist the adjuster sideways and it just slides itself off. But there are times that this technique still doesn't work.
#4934
p're, try the ball end extractor tool from 3racing...
Hey, thanks!
#4935
