Old 03-15-2005, 11:41 PM   #4366
GordonFreeman's Avatar
Oh...I got it...If I have to ask, I can't afford it!
We are the borg, you will conform, you will be assimilated. You will not stalk me to another web site.
GordonFreeman is offline   Reply With Quote
Old 03-16-2005, 05:17 AM   #4367
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally posted by Clegg
So do you get like 5$ from skyline for every time you talk about their exhaust? hehe
Old 03-16-2005, 07:50 AM   #4368
Clegg's Avatar
Gordon, if you are going to get into nitro touring to try it out at first, I would prolly recommend getting a NTC3 RTR+ For like 300$ or so you can be running and get a feel for if this is your thing. the RTR+ is surprisingly good once you spend some time setting it up. I saw some drivers last summer tear it up with one of them.
If you want to dive in with a full race ready car you are looking at a 600 - 800$ purchace. I am between 650 and 700$ into the car in the pics above sans radio hardware.
And no the track width on the car is 200mm all around, I just had it set funny on the setup board. I actually havent done any alignment or track width settings on the car yet.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com |5280 on Facebook
Tekin - Smarter, Smaller, Faster
Clegg is offline   Reply With Quote
Old 03-16-2005, 09:13 PM   #4369
BundyMan's Avatar
Originally posted by Im2lazy
The 1 degree and 2 degree hubs increase the caster as compared to the stock hub which is the 0 degree hubs. This gives you milder turn-in and more steering coming out of the corner.
On power steering as well?
BundyMan is offline   Reply With Quote
Old 03-16-2005, 10:37 PM   #4370
InitialD's Avatar
I would think "more steering coming out of the corner" would mean on power steering... No?
Old 03-17-2005, 12:27 AM   #4371
When i look at my old 2-degree-hub i come to the conclusion that it reduces the caster-effect (less camber while steering) on the outer wheel in a turn and increases the caster-effect (more camber) on the inner wheel. If the steering angle of both front-wheels would be the same (no ackermann) an you could turn like 90-degrees you would get 10 degrees camber on both wheels when caster is set to 10 degrees. Using an 2-degree-hub the outer wheel would end up with 8 dregrees while the inner wheel gets 12 degree. Because you cannot turn like 90-degree the effect is less but should be basically the same.
Robert-FW05 is offline   Reply With Quote
Old 03-17-2005, 03:47 AM   #4372
Robert, im a little newbie at this, so i must ask is that good or bad??
K9DoberMan is offline   Reply With Quote
Old 03-17-2005, 01:20 PM   #4373
FW-05RR's Avatar
thats one sweet ride Clegg
FW-05RR is offline   Reply With Quote
Old 03-21-2005, 04:36 PM   #4374
Default couple questions.
hey guys, i need some info on the springs for the fw. i have silver,black, gold, light blue, yellow, white, red, green and pink. could some body set me up with a spring lb chart or something? my other question is parts availabilty in the usa. i broke a rear arm mount last weekend and the shop says they are on back order. its the plastic parts tree with the rear tranny case on it. if some body could help it would be great!!! also some of the springs are different length long are white pink yellow and med blue. short are the light blue gold black red and green. thanks the hackmaster...
rc.hackmaster is offline   Reply With Quote
Old 03-22-2005, 12:22 PM   #4375
NiMo's Avatar
Had my first National of the year, it was a rubber tyred National at the Brookland Raceway.
Had a wee problem in Saturday practice, I couldn't get the car to turn in to the fast corners enough and felt like I was losing tons of time, but stiffening the front roll bar to a 55 degree angle gave me more turn in although it still was lacking that initial bite, also the times set others on Saturday made me feel very slow, hence a bad nights sleep with worries of being well of the pace.
Sunday came, I was seeded number 4 (46 entries) so it meant top heat.
Round 1 felt kinda average but posted me 2nd fastest.
Round 2 and the car was dialed but I read a loose car in front of me wrong and found myself on the grass so I aborted that run, it dropped me to 3rd.
Round 3 and I got on to the 15 lap pace but so did others, I'm now 6th.
Round 4 and a tweak with the rear camber (rear put to foam setting) allowed me to have a little more rear bite and was on the pace, a collision with a back marker on the last lap put me on my roof (still overtook him) so I lost time but ended up 4th fastest.
The Final started good for me, I got in to the lead and held it for 5 laps until a mistake under brakes pushed me wide on to the dirty stuff and dropped me to third, got back to 2nd through pit stops but ran a kerb too much and rolled on to the grass and this cut the motor, got going again but dropped to 6th, was slowly making up ground when at 19 minutes I lost rear drive, that's when I found that an FW05 is crap in front wheel drive mode, I struggled the remaining 11 minutes fearing the rear diff had stripped, finished in 6th and inspected the car, a rear dogbone had disappeared (well it was an original item, lasted 20 months).
NiMo is offline   Reply With Quote
Old 03-22-2005, 09:52 PM   #4376
esham's Avatar
nothing to post. FW-05RR conversion.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- shu@esham
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 03-22-2005, 11:24 PM   #4377
Trader Rating: 12 (93%+)
Default what springs for rear ?
I just wanted to know what springs people use on medium traction tracks ?
I first ran my car with out of the box settings but 37shore tyres. The rear had no traction so i installed black front springs so i use the same springs all around now.
It now handles like a slot car with full traction around the corners and lots of steering. (rrr front hubs installed)
I ask this because the rear of the chassis under the engine mount area is scraping pretty bad. 5.5mm ride height all around.
Is this fine or should i go to a harder spring on the rear ?
thanks heaps and sorry for the long post
mrgsr is offline   Reply With Quote
Old 03-23-2005, 11:58 AM   #4378
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Raise the ride height.
Racing4Evo is offline   Reply With Quote
Old 03-24-2005, 04:31 PM   #4379
Default springs
i guess nobody wants to help with any kind of a spring chart? ok fine i will have to look for my self or something. thanks guys.
Old 03-24-2005, 05:48 PM   #4380
jeffreylin's Avatar
R/C Tech Charter Subscriber
and when you find a chart, please post it here okay?
jeffreylin is offline   Reply With Quote
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 10:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 06:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 05:07 PM
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 4 09-24-2007 07:46 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 10:26 PM
SEO by vBSEO 3.5.0
