Kyosho FW-05R
#4201
Originally posted by 3434
They look like the old GP spider springs. They come in a set of six, 2 orange, 2 green, 2 yellow
At last someone gets the right answer wiyhout any clues.
#4202
Originally posted by Clegg
Nimo what pivot ball hex cap screws you using? got a place where I can score a set? the stock plastic ones suck (bind too easy going lock to lock)
Square home page for FW05R
#4203
Don't want to open old wounds but I was just wondering have people started recieving the stuff they ordered from RCmodel? I am just waiting to see so can order some spares Thanks
Twitch
Twitch
#4204
Originally posted by NiMo
New 3r Gearbox fitted
can u explain to me what did u do to protect the receiver???i cant really see how u do it.thanks
#4205
This is not a water tight solution, in mearly stops the water falling on to the receiver. If you go through standing water this set up my not work.
In heavy water I run with lexan guards to stop water flying of tyres in to shell area.
#4206
I use the Kyosho Ti pivot balls with Delrin cups made by Square which came from one of the HK site (can't remember which)
#4207
Super Moderator
Battery pack changed to a AAAhump pack and moved forward to the side if the gearbox, receiver then placed below the battery holder with holes cut for crystal and wires, it is held on by 2-sided tape, plastic from a cable tie pack cut and place over battery holder were receiver used to be, held on by the battery holder screws.
#4208
NiMo how well do the square inserts fit in the nuts? The kyosho inserts that come in the kits fit rather sloppy in the optional nuts.
#4209
Good to know
#4210
Moderator
umm how do you order from Square? hehe I dont speak their language hehe
#4211
Alternatively, you can use the Delrin cups made by kfactory (for G4).
#4212
Moderator
Yeh I havent found anyone who has any in stock currently.
#4214
Moderator
I did, never got any hits
