Kyosho FW-05R
#2596
what is needed to run the mtx 3 rear hubs? just the hubs or is more needed like bearings? thanks
#2597
This has been answered 3 or 4 times already. check back through the thread
Cheers
Cheers
#2598
I ran the FW for the first time today and all im going to say is i should have got one months ago, and thanks ziggy for lending me that shell
#2599
#2600
#2601
Originally posted by BrainTeased
no this is part of a part to convert the FW-05S to run a SG crank engine. But to run SG crank engine you also need to get the 3D clutch assembly. but im confused you want an "R" right? if so you wont need this stuff all you need is to find a .12 SG crank engine with side exhaust but im confused with your club rules as to why only allowing you to run side exhaust but with an SG crank.
I aready own the R so cant change now to the S. I am having trouble finding a engine with the sg crank which the R requires. But if can somehow fit a threaded crank using a standard clutch it would be all good. I am just hoping someone out there may already done this as I don't the money to buy bits and pieces and there not going to work.
#2603
Originally posted by jeffreylin
Thanks. Do you know if he is running the new V1RRR rear? I notice he describe the rear camber link using 2mm shim as opposed to upper or lower mounting hole.
seems more planted with the RRR conversion,I also use the front 0 degree hubs you will get mad steering. I do use the 37 Ring gears also.
#2604
Originally posted by gijoe64
I am using the RRR rear end it works very well and I like being able to change the roll center without major modifcation. The FW
Where do you get the rr rear hubs and the steering hubs from? If I can get these i'll put the mtx-3 hubs on the evo (it needs it!).
Cheers
#2605
Originally posted by ziggy12345
Hi
Cheers
Hi
Cheers
the RRR parts hit.
#2606
I am a Kyosho Team Driver, you should be able to get the RRR hubs soon. The Mugen hubs work great, I would use them untill
the RRR parts hit.
the RRR parts hit.
thanks for that. I just want to have the ball ends the same size and the axles as I need to carry mugen spares for the MTX 3 hubs. The ball ends are 8mm instead of 9mm
What are the 0 deg front hubs? I havent seen these
Cheers
#2607
new driver
Hey guys, I just built my fw this past weekend. This is my first Kyosho and I must say I am impressed. it was a very easy build and the layout is awesome. I am looking forward to kicking some NTC3 and V one RR but this weekend. Who makes stronger gears for this car. If the stock ones are weak, I would like to have the stronger ones ready for when they go. Will post pics as soon as I finish my body.
#2608
Re: new driver
#2609
Just noticed some Kfactory parts for the FW05 that I have not seen for sale anywhere.
Note the last item, 14T bevel gear, another gear ratio choice.
K1607
FW05 Alum. Middle Mount
K1614
FW05 Alum. Rear Upper Arm Mount
K1632
FW05 Hard Coated Alum. Ring Gear 39T
K1634
FW05 Hard Coated Alum. Small Beveled Gear 14T
K1607
K1614
K1632
K1634
#2610
Josh has the clutch set at 2.6mm as well! What are oters running? I tried 1.8mm today and it was great. Maybe the Siro motor doesnt have any bottom end!
Cheers
Cheers
