Kyosho FW-05R
#1561
Hey Marcos, now that you have both the FW05R and the 710, how do you compare the two? I was thinking of getting a 710 too so I am curious what you think. Thanks!
#1562
I'll sell you mine. I like my FW better despite...
#1563
The Kyosho pipe helps but I'm still at a disadvantage. I finally got my own Kyosho pipe and will be running it from now on.
#1564
#1565
The FW feels more planted yet still turning in really sharp where as the 710 is a little nervous. Also, everyone here doesn't think highly of the 710's durability. I haven't broken anything on the car but that's because I've only run the car 3 times.
I already have money set aside for a V-one RRR. My Evolution was ballistic. Belt drive is just giving me less of a hassle. I'm keeping it Kyosho through and through. These are the toughest kits I've ever owned.
#1566
Forgot to mention that I got the SP Steering plate with the different ackerman positions. Testing it Sunday. Ill let everyone know if it helps or not.
#1567
Re: Re: Re: Set up
Originally posted by Marcos.S710
can you change the front roll center?
#1568
I've fitted the Centre Conversion Kit and at last I'm not lighting up the tyres under power, and that long 1st gear makes the car feel so good (21/50*46), also the Kawahara diffs run much smoother.
These Diff wear problems, I must be lucky as I've not had any problems with mine (and I use the car a lot), maybe it's the Ceramic Grease I use on them.
#1569
Originally posted by orangbaligila
same on-power characteristics w/ one-way,.. the up-side is, you'll have a strong front brake (one-way has no front-brake)
down-side : chews the ring and crown gears even faster
Cheers
#1570
#1571
kawahara parts
hi all.the spare part numbers for the kawahara front conversion are
KF-1044?@available?@1470yen nylon top hinge pin retainer (on carbon deck).
KF-1045?@available?@@210 front top hinge pins..(you could make your own...)
this how much you should be paying for the part..any more and your getting screwed..
mike
mike
#1572
Re: Set up
Originally posted by dameetz
Anybody has got a good set up for small tight technical track with lots of 180 turn (parking lot)? I m going to race my FW on a parking lot race next week. For the past 3 days i ve been practicing at the track and couldn't dial in the car perfectly. The rear end keep on loosing causing it to spin whenever i exit the tight 180 turn on power. I m using diff at both end with 50k frt and 30k rear. Will mugen rear upright conversion make the rear more planted?
Thanks in advance.
Thanks in advance.
#1573
Super Moderator
#1574
Originally posted by ziggy12345
I havent tried the solid front axle yet. Whats the comparison to the front one way? A lot of guys say thats it improves the on power steering
Cheers
Cheers
#1575
guys really need to easy on throttle exiting corner otherwise it will spin ! to much power at the back! If it belt car, it feel like running without front belt. HELP..!!! me guy!!!
