HPI R40 Nitro Car Forum
#8986
Originally Posted by HarKonnenD
Just put on my friend's chassis that he gave me. Too bad the moron used an excessive amount of loctite...what kind I'm not sure. It's impossible to move the mounts nonetheless remove the screws.
#8988
You can get a small hand-held propane torch for about $20 at Home Depot.
#8989
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
a little less likely to burn the apartment complex...
http://www2.towerhobbies.com/cgi-bin...?&I=LXCGZ0&P=7
#8990
r40
Hi Brett,
You went from a 710 to the r40.
Why?
What did you gain?
What did you notice?
Which edition of the R40 is it?
I'm considering both cars for next season... Let me know!
thx
Why?
What did you gain?
thx
#8991
Originally Posted by RC_Greg
Hi Brett,
Why?
What did you gain?
thx
Why?
What did you gain?
thx
#8994
GPM stuff
It looks like my R40 is a semi-frozen project, which is not a bad situation. I got too busy this year and only had a time to run a bit of electric. I never even got an engine for the R40. I have changed the target to leaving it as a slightly expensive "almost static" model. It will have working steering and possibly brakes (to slow it down from 0 to, uh, 0 :-).
Ironically, I did finally find that GPM makes some machined aluminum stuff for the R40, and possibly even the rear bulkheads that I thought I would like to change. I could end up buying them anyway, to make the expensive shelf space holder even more expensive, but I doubt it.
Still, I was wondering if anyone knew anything about the GPM stuff. Would it have been good?
#8996
The most interesting thing about a nitro racer is the racing engine! dont bother with all that heavy alloy get a bargain race engine instead and bring it to life!
#8997
Originally Posted by Artificial-I
You can find a few $99 dollar engines for that static model to help bring it back to its dynamic self.
If youve never run nitro , you should give it a try. BTW what electric are you running?
As for electrics, I have a few cars. Right now I am concentrating mainly on a Tamiya TB-Evolution III and a Tamiya TA05. I like that combination because they are very different cars, but they do share a lot of parts. So it is not as costly as it sounds. In fact, aside from the extra electronics, having the second car probably only costs me about $100 US. Next year I will probably retire the Evo-III and replace it with something else. If so, it will probably also be Tamiya for the same reason.
#8998
Last of my R40 stuff
Hey guys - Just in case you don't peruse the "For Sale" threads....
R40 belts --
http://cgi.ebay.com/ws/eBayISAPI.dl...AMESE%3AIT&rd=1
R40 thrust bearings and outer clutch bearing
R40 - pinions (0.8)
I've changed over to Mugen brand and I'll be racing 1/8 scale(MRX-4) and an MTX-3 ProSpec.... I appreciated all of the help over the past year and I'm sure I'll crss paths again with many of you guys! Thanks again!
R40 belts --
R40 - pinions (0.8)
#8999
good luck....god speed.......let us know how you are doing with the Mugen.......stop in once in awhile.....
#9000
Good luck with your new racers! I hope they prove worthy weapons just like the r40 did.
Much appreciate all the helpful advice you have given me in the past
All the best
All the best
