HPI R40 Nitro Car Forum
#556
Originally posted by boom
Thanks for the picture fastharry,
I'm still baffled by this MC Escher gear design. I'm just wondering how pinions with different kinds of tooth pitch can mesh with a spur gear of one particular pitch. Since you said all you have done is gone down in pinion teeth count... that means larger teeth profile to maintain the same pitch diameter. (KMAC speaks of a variable pitch spur on the R40 that meshes to any pitch pinion. please read below)
Also..... if HPI thinks they can emulate a gear ratio change by going to coarser or finer teeth (the powerloss stuff spoken of earlier) Why are their 1st/2nd pinion+spurs all different sizes....They could make both pinions 15mm... both spurs 50mm..... and just make the 1st gear really really fine teeth... and the 2nd gear really really coarse teeth.... Why make them have different pitch diameters? (KMAC... the first and second spur gear should be the same size then)
Before anyone picks up an otherwise absent negative tone from reading my post, I just want to be able stop scratching my head for the rest of the day..... I'm not questioning anyones stated facts here.
I might have to buy a R40 just to find out what the heck is going on.
I still think I'm right with that statement. The problem with my assumption was that all the gears DO NOT have the same gear pitch. HPI (and others I guess) have decided to hold the OD constant, and change the pitch (and tooth shape) as necessary to make it work.
Now then, there have to be limitations and compromises here... they probably can't push this much further than they have (there probably won't be a 14 tooth pinion coming out in the future, for example), and there is probably increased noise, vibration and wear with the slightly mismatched gear teeth profiles, but noise, vibration and wear are not really issues here.
In my opinion, the bennifits of being able to pick any ratio and to be able to change gears without having to reposition the engine far outweight whatever drawback this is going to cause... I think it's a great idea... I'd love to give credit to whoever came up with it. They were thinking 'outside the box.' When I was in Mechanical Engineering school and took a gear design class it was just hammered into my head that the pitches had to be the same, and this defined the OD for a given number of teeth, etc. I probably never would have thought to do this otherwise, but I'm glad someone else did.
#557
thanks Harry for the response, appreciate it.
My local LHS is very good at stocking HPI parts and this car just flat out sounds good so I'm seriously considering getting one asap and most likely a new engine along with it. Though, I might wait for the version with aluminum shocks, front one way, bigger tank etc... if such a thing is even going to be released; I'm assuming it is.
I think a big part of the attraction to this car for me, not forgetting how its been said to perform obviously, but also all the talk of how easy it is to adjust and to drive, since im a newbie.
#558
Walt,
Holding OD (pitch diameters) constant... you will NEVER be able to change ratios..... you can go from a 10/20 to a 100/200 by changing diametric pitch and not pitch diameter but in the end you ratio is still the same. You have not changed your torque/veloctiy output..... you have only made you system more efficient by going to finer teeth gears.
I know you know all this..... but I just want to bring it back out to you before you write it off.
#559
Walt,
Walt,
The ratio is certainly the number of pinion teeth over the number of spur teeth, but I think it's also the pinion pitch diameter over the spur pitch diameter, and if that's true, then the pitch diameters must be changing even though the overall OD is staying the same.
#560
Just remembered... I've got my trusty Bosch Automotive Handbook here...
pitch diameter (d) = z * m
Where: z = the number of teeth
m = 'modul'
m = d/z, where 'd' in this case is the reference diameter and z is still the number of teeth... ok, so what is the 'reference diameter?' Well, it looks like Bosch assumes we know this. There is a picture shown, and the reference diameter is clearly shown as being different from the overall OD, but it doesn't go into that detail... will probably need a gear design text book to go any further into this, if necessary...
But I'm pretty happy at this point.. OD constant, pitch diameter and tooth count vary.
m = 'modul'
#561
Pinions and stuff
Guys;
The Diameter of the Pinion/Spur is irrelevant. It is the Tooth count that determines Ratio.
Diameter is only a factor in NON-toothed applications, such as "V"-belt drives or as in Tire diameter.
The reason that you can get away with this Variable Meshing, is the Gears are designed to handle considerably more Horsepower than would ever be possible in the Chassis design.
With a finer tooth pitch such as 64P, none of this would be possible.
#562
Re: Pinions and stuff
Originally posted by popsracer
Guys;
Guys;
#563
Re: Re: Pinions and stuff
Originally posted by Walt The confusion is between overall diameter, pitch diameter, number of teeth and tooth pitch (shape)... define any three of those and the fourth can be calculated. In HPI's case, they 'defined' the OD to be a constant, and then varied the number of teeth and tooth pitch (shape) to be able to get various ratios that work together with a constant center to center distance[/B]
Consider this example.... a certain 10 to 20 tooth combo has X center distance..... keeping that center distance you can (1) hold the pitch... and change teeth to 15/15... (2) hold the ratio.. and change the pitch..... 100/200 (3) mix match pitch/teeth#...... 10 teeth high module gear meshed with a 2000 teeth super low module gear.....
Are you saying HPI is doing case 3? I can see how it could work if the module were not to vary by too much.
#564
Originally posted by fastharry
ON My Serpent,you have to run both sets of gears so they add up to the same #...
#565
ingenious (although perhaps not an idea HPI came up with).
All yokomo did was change teh shape of the teeth on the pinions. The smaller pinions, like a 15th, have more pointy teeth, whereas the bigger pinions, like a 20th, have shorter and blunter teeth.
Thanks,
Steven Muller
MPP
#566
Gear changes
Guys;
You really don't even need these new design gears to run different splits. The 1M Gears on older Cars have more than enough beef to handle the less than perfect mesh. (at least in 1/10th scale)
No matter what the Diameter, Pitch, Pitch diameter, etc of the Gears, it is the number of Teeth that determine the ratio, Period.
You can have an R/C Car gear set with a 17/49 ratio, and a Machine Gear set that is 3 ft in diameter with giant Teeth and a 17/49 ratio. The reduction will still be the same 2.88 to 1.
#567
Light Weight Ti Pillow Balls R40
OK guys,
One of the secret hopups on Atsushi's R40 has recently been revealed. Check it out!
#568
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally posted by InitialD
So you must be running normal clutch shoes instead of a Centax then... I thought you claimed that you had all the hop ups available for the Impulse...
and your point is what?..
#569
Re: Gear changes
You can have an R/C Car gear set with a 17/49 ratio, and a Machine Gear that is 3 ft in diameter with giant Teeth and a 17/49 ratio. The reduction will still be the same 2.88 to 1.
So once again the teeth defines the ratio..... ONLY if..... the diametric pitch (gear pitch) of the combination is identical or close to that.
#570
Gearing
boom;
My point (and what People seem to be confused about) is that no Matter what, the number of Teeth on each Gear is solely what determines the ratio.
What HPI has done, is modify Pitch slightly to keep the outside diameter of the Gears the same, so Gears with different tooth counts will can be used without having to loosen the Motor and re-adjust mesh.
I was trying to state this in a simpler way, but maybe I was unsuccessful.
