HPI R40 Nitro Car Forum
#5656
Originally posted by Artificial-I
Yeah not only that with sometimes too short of a line the pulsing also makes the fuel foam. You can always try revving the car in front of you and seeing if this is causing the top to loose a little gas.
Watch for any of these signs. I normally try to make the fuel line the same on both sides and give a good amount of room.
A good example of fuel tubing length and use is haras R40.
http://www.superhonda.com/forum/showthread.php?t=218514
Just about everything on his car is there. As well as some nice chassis shots. Im going to be mimicking his car as much as possible.
Either that or will be buying the 2004 edition kit soon.
#5657
Re: R40
Originally posted by NovaKing
last pic...
last pic...
#5658
Re: R40
here got some pic of my R40...
Yeah next time remember the golden rules of photography.
Light , Focus , Center Object and click. If you dont have light then bump up the exposure and get a tripod.
Or simply, take the car outside on a sunny day.
#5659
Re: Re: R40
I see a black object on the screen? I guess it could be an r40.
#5660
Re: R40 clutch spring problem
Originally posted by zoloft
my R40 clutch spring giving me problem.car almost not moving even at full throttle. open up the clutch bell the spring is moving closer to the flywheel. restrore it to original position 0.5-0.8 mm according to manual. after a few run still the same thing happen again. Pls help !
regards,
azizi
regards,
azizi
#5661
Klander- The cheap way I found to get into 8th onroad is that PRP onroad car. However, some places aren't big on parts. I said NVM and just stay with the R40. I keep getting tempted into 8th onroad, but without a real car and the cost for an 8th is crazy. All the upgrades I got for the R40 are reasonably priced so thats fine for me.
#5662
Hark I'll try to send you a video clip of my R-40 with the astra body, I;m bashing infront of my house, but I lost the clutch weights and spring and didn't even notice, I thought the clutch had gone loose because the screws was a bit unscrewed...
#5663
For those of you who still don't have the HPI oficial setup sheet to tune your car.... well here you go
http://hpiracing.com/graphics/setup/r40blank.pdf
#5665
yep my lola body is on it's way, maybe then we can get the .18tz to kick some 1/8 scale but lol....
#5667
HARK I'll send you the video in a min...
#5669
Hey fellow r40ers, I'm getting close. I just need the right freakin' clutch bell bearing and I can start breaking in. I know some of you think I should shim the motor up, but I did. Nothing I could do about that. I don't have money for a new motor yet! The yokomo header works great, and after shimming up, there's enough clearance above the pulley.
I have a question, how have you guys routed your wiring? I have mine pretty close to my servo horn, and I'm worried about wearing through the wires.
Also what do you guys like to use for your throttle/brake servo?
#5670
