HPI R40 Nitro Car Forum
#526
Hi HPI R40 Guys ! :
I run a Yokomo GT4 for about 3 years now ... it has all the hop ups so you can call it a GT4-S ...
Now, even with an old design, the GT4-S its a very competitive car and until now im preparing myself and put all my illusions into participate on the next Pre-World in Brazil on February 2004 with my Yokomo. On the other hand, im getting a lot of positive feedback about the HPI Car ... and im thinking seriously on getting one ... specially cause down here in southamerica we have problems with parts and kits, but with HPI its not a problem here ...
So ... can you talk me a little about the performance of the car on the STOCK form ?, i mean, can i buy one, practice a couple of weeks and participate on a local race and the car will hold up during the practice and racing (obviously starting from the idea that im will not crash the car) ... OR it need the hop ups to be competitive in front of Yokomo's, Mugens, Serpents and other ? ...
Thanks a lot in advance for your help guys ...
PAT
PAT
#527
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
the car runs real good in stock form....it is a little heavy,but drives like it's a lighter car........very nimble on low speed S's..
its held up for me,and I have a hard gallon through it......I broke one axle..and I got t boned with my power on..that was on teh first tank..since then,no problem...
I also bent a rear hinge pin..how I don't know....but the good news is,the arm didn't break...
other then that....no problems.....
its real responsive to tuning changes...and never gets out of control....its as stable as my tc3's..and has more traction in a low traction situation....
there will be hop ups..but the car runs great out of the box..
#528
out of the box this car out performs most of what is out there today. not to put down the mugen's or associated cars but IMO the out the box feel is very responsive, stable compared to the yok's and mtx's and tc3's I've drivin straight outta the box.
My driving style is very aggressive better suited to large open tracks rather then tight technical tracks probably since I spent so much time drivin in the dirt, but since i've gotten this car i've noticed that it can tollerate my aggressive driving style and stay very controlable in the turns compared to some of the other cars i've driven. now granted I didn't build or setup the other guys cars but I was told they were box stock and set to the specs in the instructions
one thing to take note though I'm running on rubber tires (off my 6 year old NRS4 racer) and this car is amazing me since it barly breaks loose in the rear, can't wait to try it with the kit foams the traction increase will be a real bonus as it should really lower my lap times and let me carve a tighter line around the track
overall I give this kit the you won't be after driving it.
#530
armorall does work wonders, besides they are well worn but still have lot's of tread left.
the old hpi tires were made from some really long wearing rubber (probably why they changed em)
#531
i like the hpi foams so much that i order 6 more pairs of tires
#532
The R40 sounds like a real nice car. I went to my local LHS to check it out, but they didnt have one built.
Anyhow, I'm real interested in knowing more about how you can adjust the setup without a setup system. That sounds great to me. How does it exactly work and how many different types of adjustments can you make without any tools?
#533
Originally posted by fastharry
you can use a 15t pinion and 49 t 1st gear spur for a 7.909 first gear...and a 21 t pinion with a 43 t second gear spur for a 4.957 second gear ratio for a 6 tooth split...
If the spurs and pinions are based on 0.8 pitch modules like the ones found on NTC3 and the new MTX-3 or the V1RR EVO, then it is possible to use 6 tooth split gearing. This is because the finer pitch in the pinions and spurs give better efficiency in power transfer.
#534
Explain to me how pitch,and not to big of a gear ratio jump will cause the engine to bog....
#535
nobody gonna answer my question?? wtf??? i've looked all over the web to find a decent explanation of this but couldnt. wow, i thought the guys on the Mugen thread were generally unhelpful...more interested in making inside jokes and talking about KY jelly.
I thoght Fast Harry would at least answer me, considering he's ussually pretty helpful from waht i can tell concering HPI cars.
#536
-or another way-
Everything else being equal, a 5 tooth split with fine pitch gears will outperform a 5 tooth split with coarse pitch gears. Whether anyone could realistically notice it, though, is questionable, but the theory is rock solid.
#537
A big jump in gear ratio will be hard on the engine. The finer pitch on the 0.8 modules makes the large gear jump possible as not much energy is lost. You have ran the NTC3 before and I would think you should already know that when it came out, the NTC3 was the only car around at that time that was able to run a 6 tooth gear split.!
#538
#539
I would think that some of the settings on the R40 can be set without the help of a proper setup tool. I think you can do that with the toe in / out as I believe they have predefined spacers for that but not with the cambers. Don't shoot me if I'm wrong.
#540
Anyway like Professor D said the HPI uses spacers so that newbies (like you!) don't have to use calipers to get their suspension symmetrical. Wonder what happens if the spacers have tolerance issues?
Oh yeah you heard the joke about the KY jelly?
