HPI R40 Nitro Car Forum >
Old 03-20-2005, 08:11 PM
  #5011
Regional Moderator
kumpol's Avatar
Thumbs up
I drove my R40 for the first time this weekend.....IMPRESSIVE...
I was a Serpent fan for long time....and it's kind of interesting that I already fall in love with the R40 from the first day!!!!
kumpol is offline
Old 03-20-2005, 08:16 PM
  #5012
JAG Racing's Avatar
Originally posted by KLANDERMAN
Here is a pick of what's left of the flange ball bearing I ripped
I usually dissasemble the clutchbell every 6 - 8 races just so that I can lubricate this bearing ( 3-in1 oil ).
I have gone through a couple of these myself until I started some preventive maintenance.
JAG Racing is offline
Old 03-20-2005, 08:18 PM
  #5013
KLANDERMAN's Avatar
Yeah all my racing buddies have serpents, either 705, 710, or impacts, but I have always been an HPI fan, so when I heard that HPI had a pro car to compete against these serpents, I had to have... So far I like the R-40 better than those...
KLANDERMAN is offline
Old 03-20-2005, 08:21 PM
  #5014
KLANDERMAN's Avatar
JAG Racing: I guess yo are wright!!! Usually I have a check list for lubrication purposes, but I guess I totally forgot to lubricate that area, I guess know I will lube it up after every race or after a bash session...
Old 03-20-2005, 10:07 PM
  #5015
KLANDERMAN's Avatar
well i guess I couldn't wait any longer and with the excuse to order the flange bearing, I went ahead and ordered the LW chassis and a bunch of spare parts for the clutch...
Old 03-21-2005, 03:34 AM
  #5016
nsxshogun's Avatar
Yea the same thing happend to me once. But at the time I Wasnt using an HPI bearing.
nsxshogun is offline
Old 03-21-2005, 04:24 AM
  #5017
AMGRacer's Avatar
Has anyone ever toasted the flange bearing that goes in the clutch engagement with part number B019? I just took the clutchbell off and pieces of it came off... I had to special order them, as I didn't have a spare one... this sucks!!!
It is "normal" in as much as it is not uncommon. That bearing actually should not spin at very high rpm, 4-9K rpm as it is only spinning when the clutch is not locked. However the balls inside that bearing are really small and it does not take much abuse. The main cause of the bearings failing is excessive end float in the clutch causing it to "bash" the bearing, or when the clutch is slipping it way overheats the bearing and it locks and fails. My bearing is 12 months old and I have never oiled it, still in perfect condition.
AMGRacer is offline
Old 03-21-2005, 05:10 AM
  #5018
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
same here..once I got the clutchbell shimmed right,same bearing...
http://img.photobucket.com/albums/v437/dieworm/LOL.gif
fastharry™ is offline
Old 03-21-2005, 06:58 AM
  #5019
KLANDERMAN's Avatar
I guess it's normal for the bearing to wear and tear, all I need to do is oil and check it every now and then.
Old 03-21-2005, 07:18 AM
  #5020
KLANDERMAN's Avatar
Has anyone tried putting some sort of lola body on the R-40?
Is there a 1/10 scale body that looks either like the lola or th toyota GT-1?
Old 03-21-2005, 07:44 AM
  #5021
JAG Racing's Avatar
I'll take a picture of mine tonight and post it. Only problem is the body needs to be cut for front shock towers clearance.
Old 03-21-2005, 08:14 AM
  #5022
KLANDERMAN's Avatar
That great JAG please do so and let me know what type of body it is so I can try one later on
ok, so I guess you loose a little aerodynamics because of the front shock tower?
Old 03-21-2005, 09:29 AM
  #5023
007kel's Avatar
A friend of mine used the Serpent lola body on his R40, but he didn't cut the body for the front shock towers. So it looks raised in the front.
Yokomo makes a 1/10th GTP body, I'm not too sure if it will fit on the R40. I have the GTP body, I can probably check tonight if it can work on the R40.
007kel is offline
Old 03-21-2005, 09:40 AM
  #5024
KLANDERMAN's Avatar
Talking
please do so, and if you can post a picture so we can check it out..
thanx
Old 03-21-2005, 10:17 AM
  #5025
JAG Racing's Avatar
Default R40 with Frewer Lola Body
Here is a pic of my R40 with a Lola body. You can see the front shocks protruding but overall the look is pretty good I think. And talk about traction
I cut out the shock tower holes because I didnt want the body raised too high off of the ground.
Frewer no longer sells the Lola body but I think Kyosho does.
