HPI R40 Nitro Car Forum
#2911
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally posted by AMGRacer
I bolted the battery door to the chassis, so it cannot be removed from below now. You need to take off the top deck. But I never take my battery out anyways so I am not too worried.
I wrapped the battery in a kyosho balloon....and glued the balloon to the door....
I also tapped the battery door holes with a 4mm tap,used a counter sink bit to enlarge the holes,and use 4x8 flathead screws to hold the door on...
BTW,My car has a mid corner push also........but alot of on power steering out of the corner.....I put the soft springs in front,hards in the back,and that helped..
I also popped in the 4 gear diff with 30,000......uhhh,I'd say the car was a TAD loopier...
got to try it again in a higher traction situation....
#2912
I can vouch for him as well. I bought a MT12 RTU from him a long while ago and it was exactly as he said.
Proteus would your brother ship to other countries? I dont need anything right now, but it might be handy if my HK hookups fail me.
#2913
what do you guys think of top engines
same as novarossi and rex right???
reason im asking is looking through a magazine last night i saw a top tt 12 s5 i think for 189.99 and that sounds like my price range
and has anyone run the sirio evo 2?? just another engine under $200 i'd like to know more about
i will spend the big bucks if i have to to get something good quality but if i dont have to well why should i
#2914
yes, rex and top are made by novarossi, and are rebadged nova engines.
#2915
#2916
Originally posted by DOMOisCOOL
Ill race definately this summer
I personally haven't checked out RAMS yet though, when are the races?
Oh yeah, I buy my tires from overseas in HK. But everyone now is having problems with them. Good thing I got them before. RC Tech in Daly City has the HPI Foams, Nitro Shoes, and Yokomo Foams. Their tires are reasonably priced but can be over priced at times. HPI Foams cost 18 a pair
Take a look http://www.rams-rc.com
The next race is June 13. I'll be there if I have no bad surprise.
By the way, if you buy your tire online, can you post a link here?
I am really use to rubber tire, but the foam are still very mysterious to me.
#2917
Fuel to carb
Another newbies one,
how to you guys bring fuel to the carb without a pullstart. I use to block the exhaust with my finger and pull the pullstart until fuel get to the carb.
But now, no more pullstart...and the motor got so much compression that I am not able to turn the flywheel with my fingers.
How do you guys proceed?
Hint: I have an OFNA pink box.
#2918
#2919
Originally posted by Frag
The RAMS club is quite impressive. Really well organised! The web site is kind of simple though. Be patient, it's slow too.
Heres the link for the tires:
http://shopping.rcmodel.com.hk/index.php?cPath=7_35
#2920
RAMS looks pretty sweet. I might have to go watch this weekend or something.
But seeing those big cars is pretty impressive too
#2921
This weekend is the 1/5th scale though. There is less people and probably not really representative of what you'll see on the 1/8 and 1/10 scales day.
#2922
I tried the front diff instead of the one-way yesterday. Man I could not get used to the diff, it is far too hard to drive it! It is much more stable but you have to go around the circuit much slower. You should all practice with the one-way
#2923
#2924
Originally posted by 20 SMOKE
Is it worth putting the dif in for a small track with lots of grip or set up a hole car for small tracks
#2925
Well, after taking a month off racing, when I returned, I found my driving off, and the R40 wasn't on par with everyone else. I brushed the leader, "my team mate" and the R40 front knuckle popped off the pillow balls. I made it into the pits, and my pit man snapped it back on. I went out for a few more laps, to have it pop off going over a corner dot.
I was so upset with the R40, I went and got a MTX-3... After driving it hard, I found that both cars feel pretty much the same. I've decided not to give up with the R40, but I now have a reliable car that I can go too...
Anyone else have plastic problems with the R40?
