Mugen starter box
Mugen starter box
I see that there are two different colors---the purple and the grey. Are there any dirrerences betwen the two?
Man, I had troubles with the grey one this weekend. I had two freshly charged 3000NiMH sticks in there and it would not turn the engine over.
Granted the engine was a new OS but I had it pre-heated to 175*-180*. Even after a few break in tanks it still would not start the engine even with the glo plug out.
Are the OS's really that tight or could it be something else?
I am going to try some stronger packs from cheapbatterypacks.com and see what happens.
What is "SMC"?
Just change the 2 Mabuchi motors for some cheap 19 - 23 turns motors, I have Team Orion Havok 23 turns and have enough power to start anything and I do use some cheap 3000mAh packs.
Is it a new box? If so the brushes on the motors may not have seated to the armature yet. I don't know if you've had experience with bump boxes, so I gotta ask. Also make sure the flywheel is not hitting the chassis, and allow the starter wheel to spin up, before blipping the flywheel.
Searching on the net to this product it should have 2 motors.
That is your problem I think.....
Is there place for a 2nd one ?
