Centax maintenance...... >
Old 05-12-2008, 04:08 PM
Taylorm's Avatar
Default Centax maintenance......
Do you guys service your centax after every race meeting???........what is the best grease to use on the thrust assembly and what bearing oil for the clutch bearings???...............
Taylorm is offline
Old 05-12-2008, 04:17 PM
Team Kamikaze's Avatar
Use a known good molydenum grease or Black grease for the trust bearing and use the Serpent bearing Lube #1682 for your clutch bearings.
Team Kamikaze is offline
Old 05-12-2008, 05:24 PM
Trader Rating: 15 (100%+)
I use the Associated black grease for the thrust washer and 30W Mobil One for the clutch bearings. Do both before the race day starts and both before the main.
THE DOCTOR is offline
Old 05-12-2008, 05:32 PM
Trader Rating: 26 (100%+)
i use the associated black grease, works great
RANDY SMOOTH is offline
Old 05-12-2008, 05:54 PM
Trader Rating: 28 (100%+)
I used to use the Associated black grease on the thrust bearing. Now I use the Mugen Super Grease. I never oil the clutch bearings. I don't want to get anything on the clutch parts. I haven't blown a clutch bearing in years..
Scott Fisher is offline
Old 05-12-2008, 06:34 PM
s10dude's Avatar
i use high temp disc bearing grease from my truck..work's great and i've got enough to last to the 24th century..i don't oil my bearing's either..i change them once a month...from AVID Bearing's . com $1.00 ea. ( for any bearing )
s10dude is offline
Old 05-12-2008, 08:21 PM
rcabj's Avatar
i too do not oil my clutch bearings, greased the thrust bearings esp. for races and before long mains
rcabj is offline
Old 05-12-2008, 09:59 PM
Default centax
Take the clutch bell off after every race, clean the clutch shoe with denatured alcohol ( fuel and dirt get in there during fast pit stops or if you have a sloppy pitman ). Clean the thrust bearing after each day of racing to prolong its life, and Mugen Super Grease works great for the thrust bearing.
00VIP001 is offline
Old 05-12-2008, 11:38 PM
stefan's Avatar
Regular grease on the thrust bearing will stick on the inside of your body after you pull the throttle for the first time.
I use this Trinity purple stuff (the really sticky one), or a graphite spray that will dry on and leave a thin film.
stefan is offline
Old 05-13-2008, 05:04 AM
JRGTR's Avatar
After every race, remove all the centax parts and clean with no clorinated brake parts cleaner, lubricate the bearing with boca bearings high temp oil,for the thrust bearing I use Syntetic grease that is normaly used to lubricate retainers pins for brembo brakes, work great. starting the race day I pust some of these grease on the thrust bearing ans I check the bearing before the main and still have grease, put some moore and ready!
JRGTR is offline
Old 05-13-2008, 07:06 AM
Trader Rating: 101 (100%+)
Default Clutch
I too use associated black grease and no oil on the bearings. If you start to see sparks it's time to replace the shoe.
latemodel13 is offline
Old 05-13-2008, 09:35 PM
Brazilct's Avatar
i use caster oil an thrust bearing and bearing it works great
Brazilct is offline
Old 05-13-2008, 11:26 PM
Roelof's Avatar
If I am using a thrustbearing I use Tri-Flow, it is a spraycan with a teflon oil, it works great on the bearing and CVD's.
Normally When the thrustbearing is broken I place a 10x5 brass ring between the 2 steel discs to make it a ball less bearing.
Roelof is offline
Old 05-14-2008, 04:23 AM
lil-bump's Avatar
Trader Rating: 89 (100%+)
Every race day I grease with mugen super grease. I do not oil the bearings. just replace them every other meet.
lil-bump is offline
