problems with my RS4 RTR 3
I have run into a bit of a problem starting the car. I have to play with the needle to get it started. Once started the wheels spin as if the trigger is at full throttle. Again I play with the needle to get it to idle. When I get it to idle the car stalls. I have to go through this entire process again. When I get the car to keep running it moves slow. I try to adjust the needle again and the car moves on its own but I get the top speed back. After a couple of passes the car will stall if I hit the brakes too long. Could anyone help me in my time of need. Thanx
Sounds like you need to adjust your idle screw. It has been a long time since I have tuned my RS4 though...bought a XXX-NT and havent looked back yet lol.
you need to adjust all your needles. Move your idle 1/4 in, high speed 1/8 in and low end 1/8 in. Eventually i would save up for a temp gun if you don't have one.
I don't think the rs4 rtr 3 has a low end.
there is a screw on the carb that looks like it has a spring on it. Could that be the low end needle. It is on the other side of the air cleaner. Also, the needle that I have to adjust is the one that the fuel line is connected to. Thanx for the help.
The needle that attaches to the fuel line is your high end needle. Clockwise will lean it out and counter-clockwise will richen it out. Just remember, leaner is faster, but makes the engine hotter which is not good. you want to keep it around 250 degrees with that engine. I once had an rs4 rtr3 and i called hpi and they told me that engine can go to 280-290, but i wouldnt do it.
Yes, 15 FE can run at 280-290 deg-we did it for purpose it was handeling 5 tanks with no damage at all. I still have that engine in good condition, as sample how to don't do the engines. LOL
Top Gun, do you have any experience with the HPI 12R SC bump-start engine?
I have one in my RS4, and the sucker loves, and I mean LOVES, running at an average of 250 - 275 degrees [temps taken from around the head, and roughly averaged]. I have the Raytek MT4 temp gun, and the center of the head where the glow plug is, reads about 220. Different parts of the head read anywhere from 190 to 290, all while the center reads 220.
What is your technique in using the temp gun to gather temperature data?
