Kyosho V-ONE RRR EVO 2
#496
Brian,
We are having a night race at Mike's on Sat Nov 8th, are you coming?
I always value your advice and like racing with you at the track, can't never catch up to you but keep on trying.
Hope to see you at the track on Nov. 8th.
#497
I should have my diff parts by then as well so I can finally test that out for myself and see what the hype is. Tommy D says he hasn't stopped running it since trying it at that track so it must be halfway decent.
#498
Thats only Because Tommy D SR. is scared to change it . J/K SR.
I'm Also Gonna do some Diff. testing at a Tighter & lower grip track this weekend.
I know I liked the diff. alot better in the NT1 when I ran that car. But with the Evo Wc, It has so much more steering then the NT1, I have yet to try it.
I just hate giving up all that rotating mass , going from the solid to the diff.
#499
I need help from my Kyosho comrades! I have the Evo 2 and am currently running dog bones in the rear. Im sure its been brought up already but I dont want to read through the history. What is the part number for rear CVD's that will fit this car. Thanks in Advance!!
#500
Leave the dogbones in!!
#502
Thank You gentleman! Dogbones stay in the rear!!
#503
Anybody knows who carry 2Dclutch assembly?
#504
Its not enough to weigh all the rotating parts and compare them. Even if one is lighter than the other it can sap more power as it depends on its diameter.
A lighter flywheel with a bigger diameter will sap more power than a heavy flywheel which is much smaller in diameter
Cheers
Cheers
#506
Cheers
Cheers
#507
hi guys!i want to ask you if have you notice any play in the rear arms.front and back.i have some in mine rrr wc.i have try to change everything in the rear of the car but the slop is there.so i thing that it's normal.??so i shim it from the front of the arm.
does the evo 2's rear arms different?
thanks!
thanks!
#508
thanks!
thanks!
YOur not alone. I shimed the rear arms As well as the upper fronts. Also a couple of our locals here do it as well. As Far as the Evo2, I couldn't tell you if they fixed it with the newer plastics.
hope this helps
#509
its the same for the evo2... my rear and upper arms developed slop after 3 months but it did not seem to affect the handling... i shimmed it just in case anyway...
