Kyosho V-ONE RRR EVO 2
#406
Just a thought.
#407
go 38 fronts like joe said,and with lighter springs all arount.make small changes at a time.
we are waiting the reasults man!
#409
Suspended
will try this weekend thanks
#411
Suspended
you have to fit the engine mount first also the red clutch shoe engages harder than the grey shoe
#412
I take my engine in and out with the mount and everything in the car every day I race, just removing the 4 bolts that hold the engine to the mount. You have to wiggle it a bit to get past the brace on the front but it should come out without too much trouble.
I have also installed the engine with the mount attached to it, it can still happen but it's harder and I think I had to remove the side belt.
#413
#415
hi guys.do you use a special way to build your shocks?
how much % dumping are you using?
it's like 75% low traction and 0-25% high traction?
or the opposite?
thanks!
or the opposite?
thanks!
#416
Suspended
Hi,I was wondering why are the top guys not using the evo 2
thank you
thank you
#417
Sorry, what do you mean? Using where?
#418
The next major reason I can think of is that the geometry really isn't any different, there are some cuts here and there but overall none of the weight has moved around much. The big enhancement in steering is from using the evolva servo saver assembly which is just a different ackerman setting than from the evo wc. The 2d clutch is cool, but I run a Sirio clutch anyway. The rear arms geometry is changed but only because they screwed the pivot balls out 2mm and you can do that on the old car. The 2 speed is just from the evolva, I can't remember having problems with the aluminum based gears.
3rd reason, the evo2 is not as complete as the evo wc. I still recommend upgrading from the evo wc to an evo2 wc by buying the few parts it requires until the evo2 wc is available if for no other reason than to get the front/rear universals and light driveshafts.
#419
Brian, any chance you could list the evo2 items you recommend for the evo WC ?
#420
Suspended
thanks Brian
