Kyosho V-ONE RRR EVO 2
#2011
#2014
rear sway bar;
pulled the rear end apart, and im not sure if i have it on correct or not,
but when i lift one side up, the other side comes up with it (comes up same height).. and i cant push the other side down.. even with the shocks are attached, the other side comes up with it.. so its like they both move up at the same time?
while with the front, ill be able to hold the opposite side down while pulling it up.
#2015
rear sway bar;
Extract from HUDY Setup book: "Anti-roll bars are used to adjust the car’s side (lateral) traction. Anti-roll bars resist chassis roll and by doing so transfer wheel load from the inside wheel to the outside wheel. The stiffer the anti-roll bar, the more load is transferred from the inside wheel to the outside wheel. However, as the outside wheel is not able to convert all of the extra wheel load into extra grip, the sum of the grip of both wheels is actually reduced.
This changes the balance of the car to the other axle." As you can see, roll bars can make you loose grip.
Go to http://www.teamxray.com/teamxray/pro...2b8529ae6da15b, and download "HUDY Set-up Book" you will find more about setup options in there; click on "anti roll bar" on the left side menu. Or Google "radio control car swaybars" for more info. By the way; sway bar and anti roll bar is the same thing.
Kindest regards,
Lars.
#2016
anyone got a set up for a very dusty/tight track?
im installing a front diff, i cant seem to keep the rear end of the car to the ground... its like a slippery slide.
also went down from 30k to 20k in rear diff and seem to be getting heaps of understeer.. especially in the straight with a sweep.. always come out wide. so i might go back to 30k.
#2017
set up
#2018
Also can try lifting the rear end slightly for increased weight transfer --> more traction at rear
Very basic stuff. Try 'em and let me know ok
#2019
i stuffed up the set up of my car. i thought each line on the setup station was 2deg, but it was 1deg. so everything was off. i resetted my car to;
was running a front one way, but installed a spool instead.. and will goto the diff once i get the output drives.
im running the RRR WC (laydown servo), with YBSLOW titanium drive chain parts, Titanium Pivot Balls, Titanium Screws, Evo.2 rear dogbones, Evo.2 shock internals, 3mm Rear Shock tower, Carbon Front Shock tower, Ceramic Bearings,
so i changed everything back to
front;
diff = front spool
shocks = 50wt (i think)
shock position = 3rd hole up
width = 200
downstop = 0
camber = 1deg in
toe = 1deg out
spring = gold
swaybar = soft
ride height = 5mm
tires = 40@60mm trued @ 0deg (flat)
rear;
diff = 20k
shock position = middle
width = 200
downstop = 4
camber = 3deg in
toe = 2deg in
spring = black
sway bar = gold(2.3mm), but i might use the black(2.0mm) instead
ride height = 6mm
tires = 37@62mm trued @ 2deg.
Roll centre for front/rear is at B postion,
front;
diff = front spool
width = 200
downstop = 0
camber = 1deg in
toe = 1deg out
spring = gold
swaybar = soft
ride height = 5mm
rear;
diff = 20k
width = 200
downstop = 4
camber = 3deg in
toe = 2deg in
spring = black
ride height = 6mm
#2020
It was the stainless steel screws i used to mount the motor to the motor mount. They are not meant to be used there! They are too slippery and no amount of thread lock will keep them in when the car starts vibrating, there were so loose i could turn them with my fingers! It's a wonder I didn't strip both gears. They were also too long and backing out the mount screws from underneather when i tightened them down .
I changed to regular black steel and put shorter screws in it ... then of course it rained today so no racing for me .
#2021
I found the culprit so after dissembling the entire car down to bits adn checking everything i found that my chassis and motor mount are fine.
#2022
#2023
I've been motor man all day. I finished checking out my Mule after about 5 tanks through it, i changed the head and am going to finish the break in in the car. I changed the rod in my nova and my picco today too. May actually change my servo out and finish up w/ switching to titanium pillow balls to cut the last 40 grams i'm over weight off the car. The down day actually came at a good time for me but i'd have much preferred to be on the track.
#2024
ran the rear setting and the car handled 1000x better, but still wish i had more grip around corners.
the spool also made a massive difference over the one way.
#2025
great... what did you change? (other than the spool)
try softer tire compound, 35 shore maybe?
