Old 03-27-2008, 04:53 PM   #1
lifeworthliving's Avatar
Default unorthodox suspension tuning help.please look.
this is an ongoing problem that i could use some help with.. my butt comes around my head..serously. when entering a turn tha back end comes around.out of the hole shot it hooks up sweet. on power streering is great for a 2 wheel drive buggy. i dropped the back end down so its lower then the front, and use tire traction wich helps for a little bit.. should i lower the shock oil wieght or the shock piston.out of the 5 piston holes, im on the smallest 1(its hyper-adjust). but my front left tire comes off the ground as it is.. so if i go any lower, it will get worse. what if i put on a heavier spring? have many.. im set at 2* with my rear toe-in will a zero toe-in help.. im also running light diff oil. i think if i go heaveir it will be even worse.?. PLEASE.. any tips will help.. this is a 1:5 hpi 5b.. its all the same, just bigger
hpi 5b on-road, hpi rs4 evo, hpi rs4-3....
lifeworthliving is offline   Reply With Quote
Old 03-27-2008, 05:17 PM   #2
lil-bump's Avatar
Trader Rating: 82 (100%+)
You might want to post this questioned in the offoad thread. This is the nitro ONROAD thread.
Good luck...
Race you later
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-27-2008, 05:51 PM   #3
i may not have been clear..THIS IN AN ON-ROAD 5B.sorry.. off road guys wont be able to help that much.. i know its alittle diffrent then what you guys are used to, but i think the principal is still the same.. well maybe not..but just tryin to see if i can get it to handle better on the track(on-road) this is a challenge that i find way more interesting then 5lbs of mudd stuffed in my wheels..
Old 03-27-2008, 05:57 PM   #4
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
for me it has always been a heavy diff oil in the front vs the rear... but as for the shock positions i would lay the front ones out more lateral and a little more straight up in the back. as for oil weight....again heavier in the front vs back... thats my 2 cents for 4wd onroad...
other then that, can you dial out some steering on your remote?
i have also had too much steering causing your issue....opposite side of the coin......
VTA member #126
GSPOT is offline   Reply With Quote
unorthodox suspension setup..pleaze look lifeworthliving Oval, Larger Scales and More 1 03-28-2008 10:02 AM
suspension tuning rc10t4oval Rookie Zone 9 12-05-2006 02:04 PM
suspension tuning trf racer Electric On-Road 2 11-25-2003 12:32 PM
suspension tuning thread imataquito Electric On-Road 7 11-10-2003 08:43 AM
Help with suspension tuning (TC3) unknown Electric On-Road 9 02-22-2003 08:32 PM
SEO by vBSEO 3.5.0
