Chassis flex
#19
[QUOTE=British Menace Darren (Muppet Racing) did alot of work on chassis flex with the G4. As Motorman also did I think.
One of the things Darren found was, given that the modular construction of the G4 made the chassis very stiff, he enlarged the holes in the rear of the top plate and did not tighten the screws down at that point! Sometimes omitting the screws altogether! This basically meant the rear and front of the car was only connected via the chassis plate. This gave the rear end alot of freedom to roll, flexing in relation to the front of the car/chassis. This fitted nicely with the high COG of gas cars at the rear compared to the much lower COG at the front.
Darren record with the car speaks for itself.
Regards to all,
British Menace[/QUOTE]
Do you mean the two rear upper deck screws?
Regards to all,
#20
You the only person I've ever known that thought that to be honest with you. Even Alain Menu, Mr. Herbert and a guy called Michael Schumacher admit the car has the magority and is the magor factor in the overaul contribution to the race lap.......... still.
From a purely engineering standpoint............flex is out. From a drivers stand point, flex helps in driving the car's. Making them easier to drive and thus faster. But as skill rises, the chassis stiffness gets higher! Thats fact in full size car racing cause I had to take the data on exactly that myself!
In r/c.....I just think it will head slowly in that direction. And you will see less and less flex in chassis as time goes by.
But that is just my opinion.
Regards,
British Menace
#21
Having read you post again Streve....and again. I may have got tyhe wrong impression of what you were trying to say....lol. I hope you don't take offence.
Sorry that I took it wrong if that is the case.
The reason why I think there is alot more emphasis on driver ability in R/C is, as was pointed out earlier, the lack of direct imput to the driver that you can get from full scale.
Regards,
British Menace
Regards,
British Menace
#22
I think the main thing with flex in an R/C car is to start with the stiffest chassis you can get.
Get the car set up the best you can with the flex, or lack there of, you have then use "flex adjustment" if you have any (!!) aas a last fine tune tool.
Just my input into this.
British Menace
British Menace
#24
#26
Ah the old flex or not to flex question?
Well I see flex as potentialy expensive, let's say for instance your cruising down the straight at any major track suddenly for some strange reason you get a glitch or someone punts you off the track and you cartwheel in to the barriers. I would think that chassis would be easier tweaked if it flexed than if it didn't.
#27
it does to an extent, alot of things working there though. Same concept, but more prevelant
#30
