Old 03-19-2008, 02:20 PM   #1
genesisG4's Avatar
Default centax clutch question
I have an older Team Magic G4 Evo that I am putting together...finally!! I know...out of date, but brand new so we are going with it for more experience.
In assembling the clutch according to the directions the clutch spring (using the red one) appears to nearly coil bind.
Here are some dimensions
9.55mm from end of crank to clutch nut top (9.5mm +-.1mm as in directions)
9.6mm from clutch nut top to spring cup
It looks like I can get the recommended .5mm from spring adj nut to clutch nut top but the spring sure is close to coil bind.
Is this normal..I have never used a Centax clutch.
Also...the three clutch shoes came with 3 brass weights...I assume the weights engage the clutch sooner and or harder? What track conditions would or would you not use the weights?
Thanks in advance!!
genesisG4 is offline   Reply With Quote
Old 03-19-2008, 03:36 PM   #2
Trader Rating: 15 (100%+)
The weights will make the clutch engage earlier meaning lower RPM's of the engine. If the track has good traction and the rear end is not getting loose you can take out the weights so the engine will be in the higher RPM's so it will hit a lot harder and also use more fuel.
THE DOCTOR is offline   Reply With Quote
WTB: Centax clutch for G4S Dave_1 R/C Items: Wanted to Buy 0 06-18-2007 12:09 AM
Centax Clutch Question nitroaddict Nitro On-Road 14 01-27-2004 05:56 AM
noobie question on Centax clutch kimi Malaysian R/C Racers 6 06-29-2003 07:50 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
centax clutch question rccraze Nitro On-Road 1 11-14-2002 06:29 PM
SEO by vBSEO 3.5.0
