WIldcat Fuel Question
I know Fast Harry talks alot about this fuel. Which type should I be looking at for a Novarossi .12 Turbo motor with an RD Logics Turbo pipe.
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Re: WIldcat Fuel Question
Since run RB motors,I'll tell you what I use..
I run the Trinity Monster HP(Its mixed by Wildcat)...It has a 12% oil content.....You can also use yehj Wildcat Elimanator,but with 14% oil content,sometimes its just a tad trickier to tune(but has more protection against wear and overheating)..
I tried teh trinity Platinum..(which has 8%).....but I didn't see a big HP advantage,so I went back to MH...sometimes I need a little protection too
BTW,you're gonna get ALOT of answers,good and bad...Be Prepared to be
I'm with fastharry on this one.
I won't run anything other than the wildcat mixes. Eliminator, Trinity or HPI fuel are all good choices.
I also use Trinity for it has a little less oil than the other two. I've never had any problems.
i too run the trinity 20% w/ 12%
oil and it is great fuel that is easy to tune with
i got 6.5 gallons of this fuel thru an os cvr with
no problems at all , a great testament to either
the fuel or the cvr imo.
Which blend for breakin?
As stated, do you recommend the Power Blend or Platinum Blend for breakin and also what percent. Again, It is for a Novarossi .12 5 port turbo with and RD Logics Turbo pipe.
MH power blend..
