Changing Nitro % - How To Adjust Carb >
Old 07-07-2003, 07:32 PM
thefuzzclub's Avatar
Default Changing Nitro % - How To Adjust Carb
What is the general rule in adjusting the carb if you use a higher nitro % fuel. And vice versa if you use a lower nitro %.
thefuzzclub is offline
Old 07-07-2003, 09:48 PM
Default Re: Changing Nitro % - How To Adjust Carb
I personaly would go back to recomend stock settings.
with higher nitro content usually means less oil so maybe a tad richeand vice versa on the lower, use your temp gun if you got one to help you.
the best advice I could give you would be to semi re break in your engine, then let er rip
HEYALIGNMENTGUY is offline
Old 07-07-2003, 09:51 PM
EVOLUTION's Avatar
Also means higher oxygen content,so richen it up to balance air/fuel ratio.
EVOLUTION is offline
Old 07-08-2003, 05:08 PM
EdwardN's Avatar
Can I ask you something? Where is extra oxygen will come from?
EdwardN is offline
