Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-07-2003, 07:32 PM   #1
thefuzzclub's Avatar
Default Changing Nitro % - How To Adjust Carb
What is the general rule in adjusting the carb if you use a higher nitro % fuel. And vice versa if you use a lower nitro %.
thefuzzclub is offline   Reply With Quote
Old 07-07-2003, 09:48 PM   #2
Send a message via AIM to HEYALIGNMENTGUY Send a message via Yahoo to HEYALIGNMENTGUY
Default Re: Changing Nitro % - How To Adjust Carb
I personaly would go back to recomend stock settings.
with higher nitro content usually means less oil so maybe a tad richeand vice versa on the lower, use your temp gun if you got one to help you.
the best advice I could give you would be to semi re break in your engine, then let er rip
HEYALIGNMENTGUY is offline   Reply With Quote
Old 07-07-2003, 09:51 PM   #3
EVOLUTION's Avatar
Also means higher oxygen content,so richen it up to balance air/fuel ratio.
EVOLUTION is offline   Reply With Quote
Old 07-08-2003, 05:08 PM   #4
EdwardN's Avatar
Can I ask you something? Where is extra oxygen will come from?
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Forum Jump
How do you adjust engine timing on nitro engines? Jspeed Exclusive Nitro Engine Zone 122 05-13-2009 07:05 PM
changing nitro evader spoilers gillandro Nitro Off-Road 16 04-30-2008 05:36 PM
Carb Inserts...how to tune when changing them pumpkinfish Nitro Off-Road 38 10-01-2007 04:18 PM
changing nitro fuel Huffpie Nitro Off-Road 8 09-16-2007 11:56 AM
Changing Nitro content Brett.w Exclusive Nitro Engine Zone 5 02-11-2005 02:28 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
