mrx4 to mrx4x conversion
I think it is better to get a new kit
hmm
have you tried the mugen web site i have to find my sheet with the part#s i'll try & help out
T0151-B Front Lower Arm
T0161 Rear Upper Arm Mount
T0164 Front Uprigh (2°)
T0245 Front Universal Joint
T0268 Front Belt (Rubber)
T0269 Rear Belt (Rubber)
T0270 Side Belt (Rubber)
T0274 Rear Universal Joint
T0276 Front One-Way Drive Axle
H0369 Ventilated Brake Disk
T0717 Al. Engine Mount
<New Parts for MRX-4X kit>
H0136-B Rear Upper Arm
H0140-B Rear Upright
H0148-B Front Bulkhead
H0149-B Rear Bulkhead
H0188 Eccentric Hub
H0189 Upright Spacer
H0190 Brake Bracket
H0191 Rear Lower Arm Mount
H0374 Battery Holder FRP
H0466-B Rear Body Mount
H0475 Chassis
H0560 Front Damper Stay
H0561 Rear Damper Stay
H0562 Damper Case
H0571 Damper Parts
H0775 Centrifugal Shoe
H0776 Al. Pressure Plate
H0777 Clutch Bell
H0778 Fly Wheel
H0779 Clutch Shoe (Yellow)
H0780 Clutch set for MRX-4X
H0858 Ball Link 6mm (S)
New Kit
the pserson who replied with buy a new kit was absolutely correct. i have tried upgrading in the past and it does not work. Mugen tends to make minor changes without changing part numbers, or letting you know a change have been made. I am sure there are atleast one or two parts in the new kit that are different from the conversion kit. I applaud them for listening to us racers and making changes when needed, but their documentation and relay of info is not as consistent or thorough like Serpent or some of the other manufacturers. I was suprised they even did an official conversion kit. I usually hear about tweaks/changes by word of mouth and that you know is very unreliable. Mugen needs to keep their website more up-to-date.
Yes it is possible to change a MRX4 to an X ... I did it and it works great, but I did with the conversion kit. You change the chassis to the new one and the bulk heads the rear A arms and roll center blocks.
You have to take the car all apart, everything BUT the radio tray
I don't think that anyone has any conversion kits left though
Good luck
Good luck
there might be one or two left some where
sorry checked and the last one is gone
