Max Power XXL3 engines on ebay?
They are machine modified, as most out-of-the-box top engines are today. However, there is a big difference between machine modification and hand modification, like the higher cost motors you can get from Maxy, Murnan, etc.
guy hit it right on the money a lot of high end motors like novarossi rb max etc these motors come with a slight mod but the modifiers such as uriah murnan, maxy, fusion they go way beyond that and really make these motors scream.
JP and Max find the most rounded piston and match it with liners, which is the hardest combo to come by. Also, the most performance gain in an engine. The rest goes to the stock engine line that after market modder use to work on.
If you are after a pretty crank with more scoops and polished up by all means go for the after market mod. I have seen some fantastic cranks by those guys. Flowing can only do so much and by now, everyone knows what is the max you can grind out. Cutting a bit here and there and lapping unmatch piston to fit can only do so much.
gotta say my max's have been awesome, it's a shame i pitted my last one put an extra .3mm of shims on the headbutton on top of the standard .2mm shims all you aussie racers
We shouldn't be receiving XXL3's in the US probably not until next race season. I asked and the XL3 is the team engine of choice for this year., Also the XXL3 and the XL3 are not based off of the same motor, just a pointer in case you didn't already know.
I agree for the most part...but there are a few of us modders who do much more then add fancy scoops and flow mods....myself I frequently re-grind my sleeve port timings and entry angles on engines I modify , which make a significant increase in engine output, much more then just flow mods or piston matching could hope to achieve....
