Mega ZX21
Hi,
I have an engine Mega ZX21, and I have a problem with it, the pin of the cranckshaft is going out, can you tell me what should buy to replace cranckshaft ? if can be one with the pin fixed. thanks in advance |
It was a known problem in the first batch and that was the only time they used this technique. You can try to contact your LHS or the Serpent distributor for a free replacement (I know they did in the past.)
I've got a broken zx21 - the crank is fine tho - the problem is that different people made the zx21.
Originally Posted by Roelof
(Post 4051933)
thanks in advance |
If you know someone with a welding machine you can weld a small tip on the shaft side of the crankshaft and finish it with a dremel to tighten the pin. I know a person who did and it worked for him.
But this is the one you need: http://www.the-border.com/product.ph...cat=152&page=1 |
But this have the pin fix or is exact as my cranckshaft??
thanks roelof |
Directly after the bad productionseries they made a one-piece crankshaft so this one should be a fixed one.
