on off switches?
http://gasrccar.com/eshop/advanced_s...0074db&x=5&y=8 i use this..has a line/connector so you can charge your receiver pack without unplugging any connectors.............one bad thing is it has a small constant drain on your batteries.......................
Naaaaaaaa, straight plug in.
I think it a matter of choosing which way you want B+ supply to eventually fail. Over the years, I have used em all......direct solder connection, plug in connector, and switches. All three have pluses and minuses and all three can fail. Soldering really is only practical on electric vehicles. For my nitro stuff, I prefer to use a GOOD quality switch. Your going to need to spend at least 10-12 bucks to get a GOOD switch and harness......anything less than 5 bucks needs to be considered junk. Everybody thinks they solve the switch problem by direct plug in. My experience is you usually create a different type of failure by doing this. Pluging and unpluging the connector puts bending on the fine wire stands. One by one, over time, these strands break cause a degrade in connection. Eventually this turns into a intermittent or no connection at all......usually at the most inoportune time.
KO Propo Y cable : 1 (male) to Receiver, 1 (female) to battery and 1 (female) to AMB transponder.
I Everybody thinks they solve the switch problem by direct plug in. My experience is you usually create a different type of failure by doing this. Pluging and unpluging the connector puts bending on the fine wire stands. One by one, over time, these strands break cause a degrade in connection. Eventually this turns into a intermittent or no connection at all......usually at the most inoportune time.
until the connection got loose and i didn't notice how loose it was..........blamo right into the boards at about half throttle with my 960.....now i use the KO switch.........there really is no foolproof way to guard against a power outage............
i also use the ko propo switch it is probably the best switch to use but when its not in use i always un plug it
I plug my car into a slow charger the night before a race. I can usually run practice and 2 or 3 qualifiers before I use my peak charger to charge the pack before the main. I leave the switch plugged in but turned off and it completely discharges the pack.
Lee Muse
they are really good switches i love mine
no switch
less to not work.
and its a pain to put one in the car.
less to not work.
I agree with Wally, Ivan and Loveless!
Ever since i had the switch in my G4 fail and the car becoming a runaway, i have stopped using
switches and now use a 50mm long extension cable from the receiver that i plug the battery cable straight into!
Since using this method, i haven't had a runaway (touch wood)
when you have a kyosho there is a place for a switch and as long as your switch has a failsafe such as the ko swithch the switch cant really fail but yea in my eighth scale car i never ran a switch
