Old 12-30-2007, 04:38 AM   #1
Mazda614's Avatar
Unhappy Blown Plugs
I've just finished running in an OS Speed Spec II and I have started experiencing a spate of blown plugs (P7). Each new plug would last only one run. Does any one have any suggestions as to what could be the cause. I've also stripped the engine down and given it a clean, no signs of any contamination was found. Any suggestions ......
OS Speed T1201
Futaba 4PK 2.4Hz
Serpent 748 TQ
M16 Racing Fuels
Mazda614 is offline   Reply With Quote
Old 12-30-2007, 05:00 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
Blownplugs can have several causes:
- to high compression (what is very unlikeable with a new engine)
- dirt in the engine (from outside or inside)
- to lean (maybe the best cause)
- bad fuel or to high nitro content.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 12-31-2007, 03:37 AM   #3
bozla's Avatar
Possibly a damaged con-rod?
bozla is offline   Reply With Quote
Old 12-31-2007, 11:18 PM   #4
Paulie Bee's Avatar
consider adding a copper shim .05 to the head button and richen-up the motor on the top end 1/8th of a turn. keep your temp at 210 degrees or so.
Paulie Bee is offline   Reply With Quote
Old 01-01-2008, 01:49 AM   #5
your conrod needs changing. install a new one
TomB is offline   Reply With Quote
Old 01-01-2008, 08:43 AM   #6
cdelong's Avatar
cdelong is offline   Reply With Quote
Blown Speed Control. Blown Reciever? DomainG8 Radio and Electronics 6 03-17-2008 01:15 PM
Blown ESC?? wog....supraman Electric On-Road 3 10-27-2007 05:11 AM
Blown 4.5 Drewdc90 Electric On-Road 7 07-10-2006 06:21 AM
Much More PSU blown up?? VenomWorldOrder Electric On-Road 26 12-31-2005 09:02 PM
SEO by vBSEO 3.5.0
