Old 06-09-2003, 03:00 PM   #1
Marines's Avatar
Send a message via AIM to Marines
Default RS4 3 problem
I have an RS4 3 SS. I was running it today, and there seems to be a problem, where the car (im not sure if its the diff, or maybe the 2-speed, might also be the brake disc) keeps stiffening, and the car can barely move if pushed. But then after a while, the car runs normal and has no problem, it feels normal. The problem keeps happening, and it stiffens, and a few minutes later, it feels find. Can someone please tell me whats wrong. I am probably going to rebuild most of the car, but I just want to know what to look for.
Thanks, Marines
Marines is offline   Reply With Quote
Old 06-09-2003, 03:43 PM   #2
popsracer's Avatar
Two problems come to mind.
1) you have a pebble floating around in the drivetrain somewhere and it is getting caught sometimes. (less likely on a shaft drive Car)
2) A Bad Bearing causing the Drivetrain to drag.
Try to isolate each section of the Car when doing your troubleshooting. Look for the obvious.
popsracer is offline   Reply With Quote
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 07:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 08:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 06:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 04:08 AM
SEO by vBSEO 3.5.0
