Old 06-05-2003, 09:56 PM   #16
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Originally posted by ttektek
Oops sorry the two pictures are meant to other way around.
by the way, if you are using KO servo then you should use H362E spacer (where the mounting is)
Ah10 is offline   Reply With Quote
Old 06-05-2003, 10:06 PM   #17
RClover's Avatar
what i would normally do:
1) Make sure the servo are correct in place according to manual.
2) Reset the transmitter back to neutral, all trim, sub trim, trim rate..etc..
3) Make sure the steering rods are of equal lenght (you can adj. toe-out later)
4) Attach the Servo horn - dead upright as Manti said!
5) Manually move the steering ankerman to the center.
6) Adj the steering post arm in equal lenght taking measurement from the distance between the 2 points.
That's all i would do normally.
RClover is offline   Reply With Quote
m11 Not Centering ? youngie Radio and Electronics 13 09-15-2008 05:43 PM
Centering Steering Servo's hierog Electric On-Road 3 04-14-2006 10:00 PM
Steering Centering Problem A3 Nitro On-Road 22 02-02-2005 02:32 PM
JR-R1 Radio Steering Wheel Not Centering ttektek Nitro On-Road 2 05-18-2003 09:55 PM
SEO by vBSEO 3.5.0
