Old 11-26-2007, 01:57 AM   #1
paul73rc's Avatar
Trader Rating: 5 (78%+)
Questions?? Engine Tuning
Hi guys, hopefully someone can help me:
The problem is: I purchased this new HPI RS4 with an aftermarket .12 engine already installed. Ran it in. Used it several times, 1hr all up then packed it up. Bought a .18 for it, put this carby on the .18. Changed the settings for the.18engine. Put the carby back on the .12 to use the .12. Forgot the old settings (High speed and low speed needles) and now I can't get the .12 engine started. Should an average setting for both needles be 2 turns out from fully in for the high and low speed needles?
Hopefully I can get some help off the smarter guys out there!
Thanks alot, all help will be appreciated
paul73rc is offline   Reply With Quote
Old 11-26-2007, 04:50 AM   #2
Several things come to mind here.
What .12 motor do you have?
Where do you live and what is the temp / humidity level
What fuel are you running (brand and nitro content)
It is called throttle control for a reason.
rc_freak is offline   Reply With Quote
Old 11-26-2007, 07:54 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
If you can start the engine you must tune it to performance. Indicators like exhaust smoke, visable performance, sound an temperature will help you to get the right tuning. Adjustment by a number of turns is not done to get it right, exhaust pressure and the thickness of the fuel have influence on the right tuning.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 11-28-2007, 01:38 PM   #4
Default tuning
Usaually if i lose the setting of a motor , what i do is back both needles three and a half to four turns out from the closed position and go from there, and just make sure the plug is good .
p1pioneer is offline   Reply With Quote
Need help tuning my OS 28 engine! BQFTW Nitro Off-Road 5 07-15-2008 01:22 PM
Tuning Class..any SIFU (klang valley) offer engine tuning class??.. azmin Malaysian R/C Racers 17 06-20-2008 09:42 PM
Engine tuning KJT4 Nitro Off-Road 27 04-25-2008 01:06 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
Help with engine tuning airborneranger Nitro On-Road 2 10-10-2007 11:34 AM
SEO by vBSEO 3.5.0
