Old 06-13-2003, 11:42 AM   #16
popsracer's Avatar
Originally posted by ottoman
Pop's... what do you run for a exhaust manifold? The Picco exhaust is smaller than the NovaRossi type motors and most pipes I find are for the larger style.
I run the Picco (not Trinity) brand manifolds. Otherwise I can't keep Header Gaskets in longer than one race day and the tubing diameter is larger. These Engines really like the NR #51603 Pipe.
I have always removed the THIN shim in my Picco .12's with 30% and get at least 9+ gallons through them. The last one lasted about 22 months, so durability has never been an issue.
popsracer is offline   Reply With Quote
Old 06-13-2003, 10:33 PM   #17
ottoman's Avatar
R/C Tech Charter Subscriber
Pop's.... would you know of a online store that sells a Picco manifold? The ones I have checked dont list anything for the Picco
ottoman is offline   Reply With Quote
Old 06-14-2003, 08:14 AM   #18
Shim count is not as important as "actual deck height" . Take a piece of small soft solder and bend the end so it will go into the glow plug hole then rotate the piston past TDC with the solder facing the carb. You should have at least .006" per 10% of nitro as a rule of thumb when measured with a caliper or micrometer.
Ex.: .006" X 3 (30% nitro)= .018" min. ( .021" is better, especially in hot climates)
Hope this helps!
ronin8451 is offline   Reply With Quote
Old 06-14-2003, 09:12 AM   #19
popsracer's Avatar
Default Checking Deck Height
The solder method works very well and tells you EXACTLY what the deck height actually is without disassembling the engine.
Just make sure not to use anything larger than 1/16" in Dia.
I bought mine locally, but you might try 'Nitro House' online. They really have a great selection of Engines, accessories and parts, at reasonable prices. I bought a spare Piston and sleeve for my 7 port for about $60-$65 (Trinity wants $90+ for the 3 port).
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 11:37 AM
Pico .28 9 port P3 vs. Jammin .28 Off-Road teeforb Nitro Off-Road 20 10-02-2007 11:37 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 07:32 AM
ofna pico .12R inline pipe and manifold CRT_MAN R/C Items: For Sale/Trade 2 08-28-2006 05:05 PM
Werks P3 Same as OFNA Pico 26 and Orion WASP 26 KansasCajun R/C Items: For Sale/Trade 14 01-14-2005 01:54 PM
SEO by vBSEO 3.5.0
