Team Magic G4
Old 11-29-2005, 03:54 PM
Motorman's Avatar
Default Team Magic G4
well the G4S is right around the corner. so heres the scoop. These are the changes from the G4 EVO model.
l Better transmission efficiency
We re-check the car & move all the shafts a little bit to make all the shafts perfectly parallel to each other. This can largely improve the transmission efficiency.
l Better parts fitting
We modify all the nylon parts & metal parts to make them perfectly fit. No more clearence issues.
changes:
1.New alum. anti-roll bar with two adjusters on both sides (Alum. color, no anodize)
2. K1488 Universal joints, but no logo.
3.New front one-way & solid axle—we use alum. to produce the front pulley & front one-way together. One piece design. They are not separate anymore. At the same time, it can be adjusted to solid axle as well without removing the axle from the car(Hard anodized to get the best strength)
4.New K Factory low friction belts—but no logo.
5.4mm Alum. flanged lock nuts for wheels (Alum. color, no anodize)
6.Single bell crank steering system (like other cars)
7.All adjustable rods (turnbuckles) will be made of stainless steel now
8.4mm front carbon shock tower
9.New 3mm carbon radio plate (new servo, receiver & receiver pack arrangement. You can easily install servos, receiver & receiver pack now. No more hassles.
10.Receiver packs included now
11.Special receiver pack plug mount included
12.Small alum. antenna rod mount included (alum. color, no anodize)
13.Large 5mm bearings for belt tensioner
14.New type 3mm alum. 7075 chassis (w/low mount rear belt tensioner)
15.Black color alum. side plate
16.One piece alum. engine mount
17.UFO clutch set
18.New thick carbon rear shock tower with alum. mount
19.New rear anti-roll bar set
Available mid January 2006
Motorman is offline
Old 11-29-2005, 04:06 PM
Tabushi's Avatar
Parts like arms, hubs, etc etc (mainly plastic ones) are direct fit from EVO to S and viceversa ?, or its all new design ? ...
Will exist some kind of evolution kit from EVO to S ?
thanks,
Pat
Tabushi is offline
Old 11-29-2005, 04:10 PM
Motorman's Avatar
yes to the first question and yes to the second. also expect to see a crash kit (plastic parts) comming and a fully upgraded pro kit with everything right down to suspension and clutch tuning springs, option shock pistons etc. right in the box.
Motorman is offline
Old 11-29-2005, 04:25 PM
Tabushi's Avatar
Wow, great news, im sold to Team Magic since i bought my G4 EVO 4-5 months ago ... its giving me very great times in racing
So ... i will stay with it ... and buy an S version ... great that most parts will be interchangeable ...
Pat
Tabushi is offline
Old 11-29-2005, 04:48 PM
reactor's Avatar
Motorman..thats a jaw dropping specially the pro version, so you have an idea what would be the price for the 2 S? (pro and non pro)
reactor is offline
Old 11-29-2005, 04:56 PM
Motorman's Avatar
pricing has not been set yet but it will be competitive. There are alot of things going on that I cant talk about yet but in a couple weeks I will spill some more new information. It will be a suprise.
Motorman is offline
Old 11-29-2005, 05:17 PM
Car Breaker's Avatar
What will I need for converting my Mongooe to it?
is there any convertion kits or a list of parts that I will need?
Car Breaker is offline
Old 11-29-2005, 06:11 PM
ogreasurada's Avatar
This G4S sounds like a killer car! Can't wait for its official debut.
ogreasurada is offline
Old 11-29-2005, 06:33 PM
Piyo Piyo's Avatar
Motorman, will this version be available only in US or worldwide?
Piyo Piyo is offline
Old 11-29-2005, 09:08 PM
Motorman's Avatar
the S will be available world wide. The Pro Kit we plan to kit for the US market as it will be done in house. I'm sure if the popularity of our pro version kit takes off TM would consider kitting it that way at the factory. Time will tell.
Motorman is offline
Old 11-29-2005, 09:35 PM
Trader Rating: 28 (100%+)
I shall delete
Scott Fisher is offline
Old 11-30-2005, 04:09 AM
Default g4 parts
isuzuguy is offline
Old 11-30-2005, 05:26 AM
YBSLOW's Avatar
Default Hmmmmmmmm...................
[QUOTE=Scott Fisher]Dennis:
Umm
YBSLOW is offline
Old 11-30-2005, 06:03 AM
Regional Moderator
daniz24's Avatar
Yes, I second this
daniz24 is offline
Old 11-30-2005, 08:50 AM
Jea3's Avatar
Can't wait to see the new car.
Jea3 is offline
