Old 11-05-2007, 09:57 AM   #1
Default FW-05T 2 speed gear shift timing adjustability
Can I adjust the 2nd gear shifting timing for FW-05T to for example,
80% throttle ?
vic88my is offline   Reply With Quote
Old 11-05-2007, 06:27 PM   #2
Well I know someone has adjusted it to not engage the second gear so it should be able to.
headhunter is offline   Reply With Quote
Old 11-07-2007, 01:15 AM   #3
bozla's Avatar
You can't link throttle and timing, but look in the manual. There are two grub screws you can tighten or loosen to adjust shift timing. Remember - there are TWO grub screws, one on either side. It is a little bit of a chore and it might even be easier to take the gearbox apart to do it properly for the first few times.
bozla is offline   Reply With Quote
Old 11-07-2007, 04:35 AM   #4
Taylorm's Avatar
80% throttle ?
.........no, shifts by rpm............
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
need help adjusting 2 speed shift point MADaul Nitro On-Road 1 09-07-2008 01:53 PM
Where is the 2 speed shift point??? assiss Nitro On-Road 2 04-24-2006 10:45 PM
Serpent Impulse 2-speed won't shift WeatherB Nitro On-Road 1 05-08-2005 09:29 AM
2-speed problems, my NTC3 wont shift NitroBoy24 Nitro On-Road 1 02-01-2004 11:50 AM
Speed Gems 2 Jade Can It Have Timing Adjusted ibanezcollector Electric On-Road 1 12-23-2002 11:35 AM
SEO by vBSEO 3.5.0
