Old 11-10-2007, 03:16 AM   #16
Belt or shaft?
Belts are used due to less rotational mass,allowing better response and increased acceleration.However belts are sensitive to dirt so must either be totally sealed or only used in clean areas.
Shafts are used when you can't keep the dirt out,such as off-road or car park bashers.
Anthoop is offline   Reply With Quote
Old 11-10-2007, 07:26 AM   #17
belts and pulleys are capable of being altered to gain different gear ratios as well. one of the major reasons the use of a belt over a drive shaft.
jake alton is offline   Reply With Quote
shaft drive vs. belt drive plz help pH1L Rookie Zone 1 06-07-2007 04:32 AM
Belt Drive versus Shaft Drive SUNA Nitro On-Road 20 03-28-2006 08:04 PM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 04:23 PM
Belt drive or Shaft Drive tc3wood Electric On-Road 4 12-03-2004 06:57 AM
Shaft Drive or Belt Drive? dino.tw Nitro On-Road 109 05-25-2004 10:04 PM
SEO by vBSEO 3.5.0
