1/8 onroad rain tire ??? >
Old 10-28-2007, 02:34 PM
Trader Rating: 22 (100%+)
Default 1/8 onroad rain tire ???
Hi , if someone can give me more information about the 1/8 onroad rain tire it will very appreciate.
I know that type of tire are use more in Europe than in America, if you can give me info on manufacturer or web site that talk about 1/8 rain race or with photo.
Thank you, Alain.
Alain Patry is offline
Old 10-28-2007, 02:42 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Thank you, Alain.
here you go
http://www.rbproducts.com/main.php?p...tat04=KISSLING
Marcos.J is offline
Old 10-28-2007, 02:44 PM
Super Moderator
Marcos.J's Avatar
here is the 1/10th scale tire the 1/8th scale is very similar to this one
Marcos.J is offline
Old 10-28-2007, 08:48 PM
Jspeed's Avatar
Default PMT
http://www.pmt-tyres.it/epages/Store...3A8/PistaGomma
Jspeed is offline
Old 10-29-2007, 12:00 AM
Roelof's Avatar
And for a slight wet track most of the famous brands have a aqua tire in the list
Roelof is offline
Old 10-29-2007, 05:10 AM
Taylorm's Avatar
...does anyone import these to the US?
Taylorm is offline
Old 10-29-2007, 05:19 AM
Jspeed's Avatar
Try Werks Racing.
Jspeed is offline
Old 10-29-2007, 05:22 AM
tomkelley's Avatar
I think Molzer Mowery or Larrys performance RCs already have established distribution with PMT. Primarily Molzer mowery brings in their bike tires, and I heard Larry does too. I doubt they would have any 1/8th onroad stuff in stalk so you'd need to ask them to order them.
tomkelley is offline
Old 10-29-2007, 03:21 PM
Default pmt 1/8
Hi, for the PMT 1/8 rubber tire do you will need a special rim for mount it on or do will use a standard foam tire rim to glue the rubber tire to it.
If somoene use it let we know how do you do .
Do you need also a inner foam ?
Thak you for all info gived.
P.S. If somebody have good rain race picture it will be great to see it here.
Alain.
Old 10-29-2007, 03:35 PM
Roelof's Avatar
These tires are made to glue on normal rims. Get new ones or grind down an old foamtire.
Roelof is offline
Old 10-29-2007, 10:17 PM
Jspeed's Avatar
Jspeed is offline
Old 10-30-2007, 12:02 AM
Roelof's Avatar
Roelof is offline
Old 10-30-2007, 12:47 AM
The air filter sure looks well protected I hope it does have some holes somewhere for the air to pass through...
olev is offline
Old 10-30-2007, 05:09 AM
Richard E's Avatar
I observe it as a traditional photo film container upside down on a regular foam filter ... great idea ... !
Richard E is offline
Old 10-30-2007, 08:17 AM
Roelof's Avatar
Well, there is no filter inside..... yes, it is just a flimcontainer with some holes.
The idea behind it is with rain there is no dust in the air and water is always blocking air in the filter while water is comming through the filter into the engine, so why not compleetly open as in boat engines.
The holes are facing backwards so spray from the car in front of you will not spray dirty water from the track into the airbox.
Roelof is offline
