GT class--buggy-based on road!
#9616
Guys i came across something strange.....i decided to rip my Gt2 nitro racespec apart and use a e conversion from my kyosho buggy (mp777 sp1) including the single speed diff....but the front shaft was to short (90mm) tried the rear shaft to long (120mm)......need a shaft (dogbone) that doesnt seem to exist (110mm) only hpi and JQ make.....WTF? any ideas why?
#9618
SERVOS
What´s the ideal Torque/speed for steering and acc/brk servos for these cars, considering their weight.
AFM
AFM
#9619
Throttle/ Brake I tend to use the same but I would say you can get by easily on a servo with 200 oz or so.
I think throttle speed and torque is a more personal taste ..... but thats me.
Regards
BM
#9621
It was probably your lack of 'maintenance' that caused the TeamC failures because Marcus Williams doesn't like 'bashing' on his TeamC. If you don't have such a big urge to do 'race-rubbing', the Kyosho is fine for the beginner........I have statements from 'Kyosho America'.
And to set the record straight, I had to do a McGyver fix for your brand new Serpent the morning of your first outing with that car at IRCR.
I never made the harmful statements you claim I did about Kyosho, TeamC or Paolo. Marcus pushed you to misinterpret my message and sent you the PM that you admit to and witnesses have verified.
I'm amazed that someone thinks you are 'Tech-Elite'........you were going to 'pack-it-up' and go home that day until I volunteered to fix your car.
I've made no 'bold statements'..........concerning the TeamC issue, I was mirroring comments made by TeamC users that were not happy with the 'failure rate' you acknowledge. I'm not the one that 'stepped in it' here by stating the Kyosho has 'poor racability'................ A 'bold' and 'stupid' statement is is like your claim 'Paolo can spank us on 3 wheels'..........really !!
Is it still true that you have not yet been on 'the podium' at a major event. I think it will remain so because there are too many 'factory drivers' including the one that can 'spank you on 3 wheels'.
Sounds like someone needs to adjust their meds again
Move on man, its not that serious
Just for kicks lets get your explanation on what roll center does, I am sure the audience could use a refresher from a pro like you
#9622
I have some new & used Alpha tires if anyone is looking. I no longer have a GT to run.
http://www.rctech.net/forum/r-c-item...-gt-tires.html
#9623
On a Kyosho Inferno GT2... What would be a good combination for spur / pinion for great acceleration? Very high speed isn't that important. 43/46 spur and 16/19 pinion?
#9624
It depends on the engine that you are using. The spur/pinion combos you lists are great if you are using a low to mid-range grunt engine. If you are using an engine with high-end legs (an onroad .21), you might want to go to a 15/19, 15/18, or 14/18 on your clutchbell pinions. The clutch bell pinions also depend on a technical track versus speed track and small to large as far as size. Monitor your engine temps and experiment with the different combos until you find what works at the track that you are running.
#9625
Guys help me out a little bit, I've got some slack going on in my inferno's servo saver. Is there a upgrade servo saver that uses ball bearings and not just metal to metal?
#9626
Anyone? I'm kinda hoping maybe the Mp777 servo saver works? Its a 4 bearing design and looks pretty close.
#9627
Yea GTs develop a lot of slop. Something that always helps is to have a close look at where the slop is and add shims here and there. But also the ball cups and ball ends on the camber and steering links wear so it's a good thing to change them. There also can be some play in the lower arms. Basically anything that moves or rotates will develop some play at some point.
Hope this helps.
#9628
Hi!
Hope this helps.
Hope this helps.
#9629
Yea there is no slop in those places, my slop is the on servo saver and the shaft it rides on. Since its metal to metal over time it's worn out. Id like to upgrade it to a 4 bearing design like pretty much every other rc car on the market but I'm not sure if the mp777 servo save will fit.
#9630
