Old 09-26-2012, 09:25 AM   #8446
Winner's Circle's Avatar
Originally Posted by jrz93 View Post
Ok that's what I'm thinking to change to evolva gears I'm using the 008 trans could that be the issue? I'm asking?
If I switch to evolva gears I need what? The one way piece and gears n 2 speed clutch shoes? Which I have, can I use the stock or 008 shaft??
I think the gears on the 008 transmission are OK. Making the change to Evolva spur gears will require a complete re-make of the transmission. My experience is that the 008 gears hold up fine.
Kyosho makes Evolva pinions in 15, 16, 17, 19, 20 and 21t gears and they will thread right onto the VS058 clutch bell. I have had many of my customers switch over to the VS058 in order to have a larger pinion gear selection.
Lee
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 09-27-2012, 11:00 PM   #8447
jrz93's Avatar
Can u post pics of the evolva trans? I tried installing it and because of the 2speed holder it pushes the gears too far fwd am I doing something wrong?
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 09-28-2012, 09:28 AM   #8448
I modified the Evolva first gear spur to fit the stock Kyosho one-way and it gave me a better gear selection. You have to ream the first gear center and slightly open one of the screw holes. It has been durable and worked great.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 09-28-2012, 09:51 AM   #8449
jrz93's Avatar
i have also but the 2nd gear holder is too wide and pushes the gears too far fwd, if someone can put up pics of a blackhawk or evolva 2speed id appreciate it so i can have a spare trans available, ill stick with the 008 i guess, also does anyone know if the 008 one way and the stock the same?
Old 09-28-2012, 10:52 AM   #8450
bigjez's Avatar
Thinking about a prototype build after the dm1 if i ever get to it. ..who has the best 2speed that i can use on the other car thanks.
bigjez is offline   Reply With Quote
Old 09-28-2012, 01:33 PM   #8451
I would say OFNA or Serpent. But most of the time the OFNA is too large to replace most of todays center diffs of any buggy. So that leaves the Serpent on that is very compact and it comes from the 1/8 pan car so it can handle extreme loads.
jneg is offline   Reply With Quote
Old 09-29-2012, 07:25 AM   #8452
Grenade10's Avatar
Trader Rating: 37 (100%+)
What chassis are you looking at? I've got a Mugen 2 speed with gears converted from the MRX sitting on an OFNA chassis ........
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 09-29-2012, 07:27 AM   #8453
Racerx336's Avatar
Trader Rating: 34 (100%+)
I am really thinking about trying the GT class since we just had a new track open in the area. Anyone have a used GT car for sale?
-Andrew Clark-
/ Nemo Racing USA /Agama / Pro-line Racing / VP Powermaster / RC Shox / Triton RC / Dutch Oven Designs / Paradise Air / TIX RD /
Racerx336 is offline   Reply With Quote
Old 09-29-2012, 01:05 PM   #8454
bigjez's Avatar
I have a dm1 with the truggy chassis and i need a 2speed for my odonnell z10 conversion.
Old 09-29-2012, 02:05 PM   #8455
Grenade10's Avatar
PM me your e-mail and I'll send a picture of what I have. Check the distance between the screw mounts and send that info as well. I have this set up to work in the DM-1 Spec Chassis.
Old 09-30-2012, 06:53 AM   #8456
Originally Posted by Winner's Circle View Post
I have the VS058 on my car and I use Evolva gears and I have not stripped a spur gear ever. Note - I am using a Blackhawk transmission (made from Evolva gears - this is no longer available).
One thing that may be contributing to you stripping gears is misalignment. Gear mesh is very important but also you need to have as much of the pinion aligned and in full contact with the spur so that you get 100% contact or as close as you can get.
I had to do a lot of shimming when I went to the VS058 and I had to put a spacer between 1st and 2nd gear pinions in order get a good full gear to gear alignment.
Lee
What did you use for shims? I'm having a hard time finding shims that fit properly. Thx
redliner140 is offline   Reply With Quote
Old 09-30-2012, 07:24 AM   #8457
Do they sell the whole Serpent 2 speed as 1 item or do you have to buy each piece separate. Thx
Old 09-30-2012, 01:20 PM   #8458
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
GT class--buggy-based on road!
They sell the 2 speed gearbox but no shaft included, part # 902410
http://www.serpent.com/product/902410/
FREELANCE_RCer is offline   Reply With Quote
Old 09-30-2012, 05:01 PM   #8459
Found this, and it shows the evolva gears post #8 & #9. http://www.rcuniverse.com/forum/m_71...tm.htm#7313968
Old 10-01-2012, 09:51 AM   #8460
I have a kyosho on the 777 chassis with a modded two speed using the evolva stuff. It ran second at the rc pro series national in Houston. I can sell it as a roller or rtr. Asking $300 for roller. Many upgrades. Titanium, straight cut heavy duty diffs, light weight universals.
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
