GT class--buggy-based on road!
#8341
#8342
Thanks Daniel,
The 2-speed and a few other goodies have been completed since
We will be at the TimeZone race in 3 weeks how about you comming there
We still have a few dates across the country to make this season we will see about comming back, maybe we can make a Dallas race too
Hope you have good fortune with you Serpent it looks great
Thanks Andy. Making the A main at the Nationals with the Single speed and without the other improvments and finishing 6th that day really said alot to me about the cars potential.
Now with the 2-Speed and other improvements we just need seat time to dial it in, speed is not a issue
See u at the Timezone Andy
It's been tough just making it to any races here in Texas due to work and my daughter's tennis. Hoping next year I can do more racing. I will be heading up to Dallas for the next series race and plan on making the Region 9 event and the Gulfcoast Grand Prix. Where and when is the Timezone race? Maybe I can try and make it to that one. I'll keep you posted.
Regards,
Daniel
#8343
Leon,
Regards,
Daniel
Regards,
Daniel
#8344
#8345
Help a brotha' out pls...
I have been running the basic Jspeed seet up for a LONG time - and I even have the sheet. BUT it's printed somewhat small when compared to the 'new' Inferno GT sheet and I'm having trouble reading it since it got near some form of oil that soaked through the sheet...
Jspeed or anyone else still have a copy of this that they could either post or post a link to????
Thanks!
Thanks!
#8346
Anybody know where I can get Alpha tires from? IGT hobbies and maxvelocity both show out of stock. Looking for pre-mounted white wheels, hard shore.
#8347
I believe brucknerhobbies.com has them
#8348
Thanks!
Thanks!
Off the top of my head here’s something new you might want to try on your IGT car depending on surface condition and driving style now:
Front Toe out: +0.5 or 0 degrees
Rear Toe in: -2.5
Ride height: front 9mm – rear 10mm (8mm – 9mm if track is super smooth)
Front upper pin – lower shock tower position
Rear inner upper link – lower shock tower position
Rear anti-squat lower pin holder – Optional Red
Rear wheelbase – plastic spacer behind uprights
Springs: Stock
Shock oil: 80W
Shock location: front outer lower- inner upper & rear – outer lower-middle uppers
Droop – front 1mm, rear 1 to 2mm
Camber – front -1.5, rear -2.5 (change angles depending on tire wear patterns)
Diff oils:
Small tight tracks: Front - 30K to 50K & rear 10K
Big open tracks: Front 200K to 300K & Rear 20K to 30K
Hope it helps!
#8349
Thanks!!!
I think it will; I hate it when I SAVE a set up sheet, find it and then can't read it....
I consider the Lincoln, NE onroad track a medium track so I'll probably start with 100 - 120 front and 10 rear - possibly fill an extra diff at 20k just to settle it down if it needs settleing!
Otherwise, I can read it and it seems pretty much what you have posted here!
Thanks again for your help!
#8350
Thanks!!!
Mark W.
#8351
Glad to see you're making it back over this direction - I really wanted to make the Fireball BUT my wife seems to be a bit grumpy when I race on holiday weekends!
So, as long as everything goes as planned today, I'll finish prep on the Kyosho, start to break in motor and PACK MY JUNK so I can leave about 7:00am in the morning!
#8352
LOL!!! Actually, I *think* I won't have to go too far; I think we'll be pitting side by side! Billy invited me to pit over that direction since I'm the only one coming from down here with IGT and I didn't wanna' wrestle an easy up by myself.... So, I'll be the old fart with the white Taurus and the freshly prepped Kyosho nitro and a shiny new GT8e to 'shake down' and see if it's even worth trying to perfect!
Now that is funny. I'll leave mid afternoon today, as I have a little farther to travel.
#8353
AND, I may toss the Easy Up (one of the worlds GREAT oxymorons) just in case we need more shade or a coctail lounge area or such....
Looking forward to running the IGT for the first time in almost 2 years!!!
#8355
