Old 04-17-2012, 08:10 PM   #8176
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by jneg View Post
Ok, first since the 2 speed uses a solid center shaft it doesn't matter if you have both brakes up front or 1 and 1. The only thing that really matters is how fast the heat buildup can be disipated by them. So it is much easier to cool them with one in front and one rear. Second true brake vias can't be adjusted like in a buggy with a center diff but you can simulate the effect. By having one brake engage first then the other. To do this you need to have two brake levers. I use RC8 brake disks and RC8 brake linkages. With this setup you can have the rear lock earlier or later or any way you want. The disks are excellent and last a long time plus their compund grabs even with some fuel on them. Another Plus is that they have an inner aluminum center that dissipates a lot of heat. They are not direct fit but with some dremel work you will have more than enough brakes to lock them up at will. I have even had to remove brakes because they work soo good.
+1 on this set up .... Works as noted, also with both pads seems total heat is less over a long run. My 2 cents.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 04-17-2012, 08:21 PM   #8177
briankstan's Avatar
Do you have any pictures of your setup? I'd like to see what you have done.
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 04-18-2012, 07:45 AM   #8178
BIGCAT TX's Avatar
I only have the brakes in the front....I use the upgraded pads/disc as well as using a small spring in between to keep the apart when not braking. This way you can have a bit more space and when you let off brake it cools quicker by keeping the pads apart.
One thing I learned last weekend was that if I can get my car set up properly with the correct diff fluids I didn't need all the braking power I previously did by driving to hard into the corners. Having a set up to roll into the corner and pull out quicker under power allowed me to drive with almost zero brake needed. I only used brake when I was in traffic, otherwise just rolled through the corners.....
If you are using that much brake to heat it up and melt the plastic cup on the two speed holder your set up or driving style probably needs attention.
BIGCAT TX is offline   Reply With Quote
Old 04-18-2012, 09:31 AM   #8179
tonylunatic's Avatar
Trader Rating: 44 (100%+)
2012 RC PRO SERIES ON-ROAD NATIONAL CHAMPIONSHIP
IGT AMAIN- FIRST 9MIN
http://youtu.be/Ec6KZALSLwA
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is offline   Reply With Quote
Old 04-18-2012, 09:47 AM   #8180
Has anyone tried the LRP ZR.30 in a DM-1 or IGT? They are being sold off at rock-bottom prices here - €60.. Used to be €200+.. Anyway, I like the idea of getting one and breaking it in in my DM-1, then later throwing a backplate on it and having it for my LST2's...
So far I feel like the gearing in my DM-1 needs more grunt anyway. The 21's and Mach 427 I've tried haven't even pushed it up into the 50's(mph) yet.. The little Rally Game tires are surely a factor there too... Still, I feel like it needs more muscle to push the gearing, as opposed to massive revs with some race .21... Could be wrong though - dunno'.. Do like the advantage of having an engine that can be run in several of my RC's(DM-1, SC8, LST2's, etc..)
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
Old 04-18-2012, 10:22 AM   #8181
Solara's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Speyederjedi View Post
When I had my DM-1 I changed it to a front rear set-up (1 in front of the 2 speed and 1 in the back) so I could adjust how I control braking front to rear. I liked it much better that way because it didn't upset the stance of the car as much under braking. IMO going to a front\rear brake setup is better.
Regards,
Daniel
Originally Posted by tonylunatic View Post
I agree the front rear setup works the best.But use the upgraded pads and rotors.
Thank you all.....now, what upgrade brake pad/disc that I should buy...? Brand and model # please...thanks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 04-18-2012, 10:23 AM   #8182
Solara's Avatar
You have a picture to show what does that look like..? Thanks.
Old 04-18-2012, 11:31 AM   #8183
Winner's Circle's Avatar
Originally Posted by Herrsavage View Post
Has anyone tried the LRP ZR.30 in a DM-1 or IGT? They are being sold off at rock-bottom prices here - 60.. Used to be 200+.. Anyway, I like the idea of getting one and breaking it in in my DM-1, then later throwing a backplate on it and having it for my LST2's...
I am running a LRP .28 in my GT2. The engine is very impressive and turns faster laps than this same car did with a RB.21 Rody Roem engine installed. I think I paid about $170 for this engine and it is really fast with strong pull off the corners.
We are limited of a max engine size of .28 so I have not tried the .30. However if the .30 is anything like the .28 then it will be a great engine.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is online now   Reply With Quote
Old 04-18-2012, 11:33 AM   #8184
Trader Rating: 54 (100%+)
Default DM1 dual brakes
Here's a pic of my dual brake setup. You can see that it is just two identical setups on each side of the 2 speed. This is using the RC8 linkage parts. I'm using the Ofna CNC brake disk and sintered pads. (those are Kyosho pads on the back just because I had them lying around, the Ofna ones actually fit better).
WatchOut is offline   Reply With Quote
Old 04-18-2012, 12:05 PM   #8185
Solara's Avatar
Thank you....very detailed information.
Old 04-18-2012, 12:38 PM   #8186
Yes that's how I have mine. The difference is that I use RC8 Brakes as well. But the linkage set up is the way to go.
jneg is offline   Reply With Quote
Old 04-18-2012, 12:59 PM   #8187
VexVegaz's Avatar
Finally got my GT2 back together after being ran over by a car
before..
now..
Thanks to brooklyn hobbies for the great price and leon for the misc parts and hump pack, much appreciated!
Serpent Cobra GT > Serpent 748TQ Serpent S411 Serpent SRX2 Sanwa MT-4 Novarossi Hobbywing Epic D3 Savox > Sweep Tires > BrooklynHobbies.Com
For RC TShirts and Custom Sponsor Shirts & Hoodies, Please Visit www.veytrex.com
VexVegaz is offline   Reply With Quote
Old 04-18-2012, 03:31 PM   #8188
Originally Posted by Solara View Post
DM1-Spec owner....is there any benefit to have double brakes? If so...2 disk double brake in front of the 2-speed gear box or like some truggy with 1 front 1 back at the 2-speed...?
The Dm1 Spec I have has 2 disc brake system on the front and I am wondering I should add one at the back....thanks.
Howard.... You doubt me
Awesomatix USA, AVID, Serpent USA / Desoto Racing, Team Scream, LRP, Psycho Cells Racing, Sweep Racing, Hurricane Motorsports, Core Creations, Hobbytown USA of K.C., 2mm Design and ProLevel
BSYDOR is offline   Reply With Quote
Old 04-18-2012, 03:33 PM   #8189
Oh your torturing me... Aren't you
Are you sure you still love me?..
Old 04-19-2012, 05:26 AM   #8190
VexVegaz's Avatar
Can you guys recommend a hauler bag that has a tools compartment at the top and can fit a gt2 that's priced around 100 - 150. I hate having to haul around a tool box and the car and the Tx.
Thanks!
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
