Old 04-14-2012, 07:49 PM   #8161
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by jrz93 View Post
I'm sorry if it was quoted already but is the serpent gt accept the same length body if a Kyosho gt1 or longer gt2 body?
I believe it is the same length as the DM1 Spec 1/8th or the short Kyosho. Watched it in person this weekend, and it looks good.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 04-16-2012, 10:22 AM   #8162
Speyederjedi's Avatar
Originally Posted by BrakeTurnAccelerate View Post
Body looks really good. If I may, where'd you get the clear Kyosho Ferrari body? I've been on the hunt for one and haven't been able to find one..
I ordered it from Lee at Winner's Circle.
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 04-16-2012, 02:47 PM   #8163
Winner's Circle's Avatar
Did it arrive OK?
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 04-16-2012, 03:01 PM   #8164
Originally Posted by Winner's Circle View Post
Did it arrive OK?
Lee
Yep!
SWEEP Tires
Old 04-17-2012, 06:20 AM   #8165
jrz93's Avatar
Can someone confirm this? As I want to have my painter start on an alpha r1 body but I need to know if it fits first
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 04-17-2012, 06:20 AM   #8166
jrz93's Avatar
Desotos? I preordered mine at my lhs and just wanna know what body fits thank you
I currently have a mcclaren body and corvette will these fit or should I order alpha r1, r2, or r3?
Old 04-17-2012, 07:10 AM   #8167
mosaics12's Avatar
fits gt1
kyosho inferno GT2 pro.. kyosho ultima sc.. HPI savage X.. tamiya m-05 pr
mosaics12 is offline   Reply With Quote
Old 04-17-2012, 08:13 AM   #8168
BIGCAT TX's Avatar
All the bodies will work on most of all of the cars...none are an exact match. You should cut your body out on the car before you paint anyway.....just makes it easier to fit the body right.
BIGCAT TX is offline   Reply With Quote
Old 04-17-2012, 01:40 PM   #8169
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Originally Posted by mosaics12 View Post
fits gt1
On Alpha RC :
R1 : For long chassis 1/7 like Ofna DM ONE and Kyosho GT2
R2 and R3 : For short chassis 1/8.
R2 is near Protoform PF8 like, but faster as is lower and has a great rear downforce. R3 is faster and a little more "loose", great for high speed open turns and flowing tracks.
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-17-2012, 02:19 PM   #8170
The R3 fits perfect.
desotoracing is offline   Reply With Quote
Old 04-17-2012, 03:38 PM   #8171
Solara's Avatar
Trader Rating: 16 (100%+)
DM1-Spec owner....is there any benefit to have double brakes? If so...2 disk double brake in front of the 2-speed gear box or like some truggy with 1 front 1 back at the 2-speed...?
The Dm1 Spec I have has 2 disc brake system on the front and I am wondering I should add one at the back....thanks.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 04-17-2012, 04:05 PM   #8172
When I had my DM-1 I changed it to a front rear set-up (1 in front of the 2 speed and 1 in the back) so I could adjust how I control braking front to rear. I liked it much better that way because it didn't upset the stance of the car as much under braking. IMO going to a front\rear brake setup is better.
Regards,
Daniel
SWEEP Tires
Old 04-17-2012, 05:10 PM   #8173
tonylunatic's Avatar
Trader Rating: 42 (100%+)
Regards,
Daniel
I agree the front rear setup works the best.But use the upgraded pads and rotors.
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is offline   Reply With Quote
Old 04-17-2012, 05:34 PM   #8174
Listen to Tony on that one. You'll be glad you did.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 04-17-2012, 08:08 PM   #8175
Red face
Ok, first since the 2 speed uses a solid center shaft it doesn't matter if you have both brakes up front or 1 and 1. The only thing that really matters is how fast the heat buildup can be disipated by them. So it is much easier to cool them with one in front and one rear. Second true brake vias can't be adjusted like in a buggy with a center diff but you can simulate the effect. By having one brake engage first then the other. To do this you need to have two brake levers. I use RC8 brake disks and RC8 brake linkages. With this setup you can have the rear lock earlier or later or any way you want. The disks are excellent and last a long time plus their compund grabs even with some fuel on them. Another Plus is that they have an inner aluminum center that dissipates a lot of heat. They are not direct fit but with some dremel work you will have more than enough brakes to lock them up at will. I have even had to remove brakes because they work soo good.
jneg is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 12:03 PM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 07:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 12:40 PM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 11:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 02:05 PM
SEO by vBSEO 3.5.0
