Old 05-19-2011, 12:49 PM   #6166
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by Pit-racer View Post
Cool , he knows where I live!
i like that one...but on the real serpent should be taking money and bring out this car ...if any changes need to be made hell i buy the updated car
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 05-20-2011, 08:37 AM   #6167
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys,
This is for a friend in Peru.
He is using a DM SPEC with offroad .21 engine.
The thing is that, based on what he is explaining me, it seems that the 2 speed setting springs get warm/hot and softer after couple minutes of run so at start the shifting point seems perfect but after couple minutes it starts to shift early and early as the springs gets softer ...
Any tip to solve this ??
thanks in advance guys ...
Pat
Tabushi is offline   Reply With Quote
Old 05-20-2011, 08:48 AM   #6168
Clete Landefeld's Avatar
Originally Posted by Tabushi View Post
Guys,
Pat
Keep in mind that the tune on the motor will change the shift point as well.
IF you are rich, the motor takes longer to get to the RPM to make it shift...So as the car warms up my shift point is too slow...as the car comes up to temp at say, 170 degrees... the car shifts perfect. In short, make sure you are at operating temp before you make adjustments.
there is a hole in the 2nd speed clutch bell rotaate the shaft until you see the set srews,(2) back both off EVENLY..SMALL amounts.. VERY SMALL... Turn in to make is shift later, Out to make it shift earlier....
I hope this makes sense.. I am sure there is a Youtube Movie about this someplace...
Clete
SnotRocket Racing, Team TimeZone, Kamikaze Toys and Hobbies, McKune Design, RC Plus... Thanks for all the help guys!
Clete Landefeld is offline   Reply With Quote
Old 05-20-2011, 08:50 AM   #6169
Tabushi's Avatar
Im clear about all you posted, and thanks ... but the thing is that, there exist some harder adjustment springs ? ... i think that the stock ones, tend to get softer after 15 minutes of racing ...
cya
Pat
Old 05-20-2011, 08:51 AM   #6170
[QUOTE=Clete Landefeld;9140090]Keep in mind that the tune on the motor will change the shift point as well.
+1.
triple7s is offline   Reply With Quote
Old 05-20-2011, 08:57 AM   #6171
There are aftermarket springs and chutch shoes (Aluminum).... I have not used either as of yet.. I am new to the car as well...so I am still on the stock ones... We tested for 30 min straight last weekend.. Just to check tires and temps.... the car seemed fine.. But our track is very large and it not shifting as much as you might think... maybe 6-8 times a lap..
Good luck... share what you find out..I am interested to hear the feedback.
Clete
Old 05-20-2011, 09:20 AM   #6172
Guys,
Pat
I don't beleive that to be true. The spring and shoes will take a set, but after that your engine tune is going to affect the shift point more than anything.
If after a couple of minutes your shifting early, it's because the engine has warmed up and running leaner than when you started. Set the shift point after after the engine tune is consistent (during practice of course.)
williamw is offline   Reply With Quote
Old 05-20-2011, 10:08 AM   #6173
I also notice that the shift point seems to change the longer I run.. Mine actually seems perfect earlier rather than later - so once I'm at 250F or so it's shifting too early.. At 200ish or even cooler it's perfect.. Could this lead to problems with shredding spur-gears or CB bearings?
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
Old 05-20-2011, 10:48 AM   #6174
mosaics12's Avatar
anyone know a pros and cons of usin a D8 tank? its a clunk tank.
mosaics12 is offline   Reply With Quote
Old 05-20-2011, 11:24 AM   #6175
Jspeed's Avatar
Guys,
Pat
Pato,
If its not a tuning problem, check the size of the springs against new ones, maybe they're wore out or have lost spring tension. Just another idea to check. good luck
Jspeed is offline   Reply With Quote
Old 05-20-2011, 11:44 AM   #6176
Tabushi's Avatar
Originally Posted by Jspeed View Post
Pato,
Thanks ... as this is for a friend i preferred to come here and share the query.
Im pretty sure is not a engine tuning related issue, is only about the 2 speed systems, specifically on springs ...
Jeff, do you know if exist some other source for this little springs that are more resistant to temps ? ...
thanks !
Pat
Old 05-20-2011, 11:48 AM   #6177
Jspeed's Avatar
thanks !
Pat
Maybe check the 1/8 Serpent, Mugen or Kyosho springs. Is also possible that a hard 1/10 scale spring might work too (must be from a pro-level car, ok). Just have to size them up against stock DM1. Good Luck
Old 05-20-2011, 02:21 PM   #6178
gashuffer's Avatar
Trader Rating: 48 (100%+)
Clunk tanks usually are for off road. Being that your chances of being turned over are greater.
T-Sal
gashuffer is offline   Reply With Quote
Old 05-20-2011, 02:38 PM   #6179
Gary NJ's Avatar
No cons. The D8 tank is excellent, and inexpensive to boot.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 05-20-2011, 03:21 PM   #6180
gashuffer's Avatar
Got my Warrior in the mail today!! Still have to finalize some trimming.
T-Sal
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
